I Think I Broke Something - Defender Source
Old August 2nd, 2010, 10:32 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
Drove over Mossquito Pass, Colorado Saturday and I think the D90 did not like it because it started to act up going home. Here is what is going on: driving down the highway at a constant speed everything is fine. No noises, no rattles, no shaking just a normal ride. Push on the accelerator suddenly and the vehicle shifts to the right just as if it was hit by a gust of wind but there is no wind! Steering wheel does not move. If I let off the accelerator suddenly the vehicle move to the left. This is the only sign that something might be wrong. Looked under the vehicle and could see no obivous signs of trouble. Thohgt it might be a broken engine mount but not that. Any idea what to check?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old August 2nd, 2010, 10:59 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Bushings?
Embarrassed to say I haven't been over Mosquito Pass in ages.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old August 2nd, 2010, 11:16 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
It was an interesting trip. The group ahead of us on the pass were a bunch of CJ2's and CJ3's, the first generation 4WD and in our group were LR3's the latest generation of WD4. Both groups made it over the pass with no MAJOR problems.
The Wizard
Old August 2nd, 2010, 11:19 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
rear steer from loose rear link bolts or blown rear link bushings..
Old August 2nd, 2010, 11:20 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Check the trailing/radius arm to frame bushings. If they are shot the truck will do that.
Old August 2nd, 2010, 01:37 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
^^^^ agree.... trailling arm bushes (either end) or radius arm-to-chassis bush on the front.
Old August 2nd, 2010, 01:49 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Went out and had the same problem on I=25, the nut was loose on my left-hand rear trailing arm.
Bill
Old August 3rd, 2010, 10:29 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
Problem found and fixed. The right side trailing arm was loose at the front mount. All is well for now.
The Wizard
Front Air Vent Lever Broke...Argh! boshea Defender Technical Discussions 5 February 15th, 2006 08:08 PM
Broke Down Help Campbell Defender Technical Discussions 3 August 30th, 2004 05:29 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
Broke the 500 mark chrisvonc Misc. Chit-Chat 15 April 11th, 2004 04:07 PM
My viscous coupling be broke! dboehme Defender Technical Discussions 6 October 6th, 2003 11:32 AM
» Defender Registry
CTX
4RF RDS
Jon Snow
huibae
Add your Defender
