I solved my stalling! - Defender Source
Old December 18th, 2012, 08:58 PM
wantone
Rick Thompson
94 ST #1222
I seem to have solved my ongoing mysterious stalling, sputtering etc i had spoken about in two previous threads. I replaced the ground w/a 1/0 battery ground from NAPA. I bolted it to the cross member, cleaned the bolts & all conact points on the frame, smeared dielectric grease on it. Then took a short cable from a winch & bolted it to the block & the frame.
Old December 18th, 2012, 09:08 PM
Probably a better idea to update your other threads with the resolution than start a random new one, no?
Old December 18th, 2012, 09:12 PM
dude you missed the perfect lay up for a spot of irony ...
wantone
Rick Thompson
94 ST #1222
Good idea. I figured no one would read the ecu thread if they had stalling probs & if they saw this, maybe they would try this solution as it only cost $35. Rather than replacing the alt, stepper, ignition mod like i did. But i will update them.
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Stalling RR? headdamage Defender Technical Discussions 5 March 20th, 2005 12:29 AM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
Why is my D90 stalling? JRowe Defender Technical Discussions 4 November 10th, 2003 04:17 PM
