I really need help... - Page 6 - Defender Source
Old November 25th, 2005, 09:46 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I've decided after nearly getting run off the road going to the parents for turkey my next rover will be one of the above pictured recon trucks!! Mybe then people won't try and hit me.
Jimmy Buffett
Old November 26th, 2005, 01:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
They do have a certain presence ( and good allround visability)
The rear gunner could prove handy
Mike Hammond
Old November 26th, 2005, 01:46 PM
Originally Posted by JimC
Thats great Jimmy, that will put it in Mike's yard.
I guess its just a matter of whether or not he'd rather have it sitting in his yard or at BWO.
I dont just want to dump on Mike to have to fix it up to the point its road-worthy - it all depends on what he wants to do.
OK I talked to the powers that be (my parents ), first my mom was like no way 2 rovers dead in the driveway, but then I told her about the epic adventure across the US and she was all for it, as long as there isn't 2 defenders in the driveway all winter long.
So at the least if we can get it towed to my place I cna look her over. Jim I'll talk to Jimmy to see about the AAA thing. I'll also send you a PM with my cell # to talk over any details. It'll be prety cool if we can make it happen. If not, hopefully shipping from here in Manchester is cheaper
Old November 26th, 2005, 04:24 PM
mikeslandrover
Mike Hammond
back on track again
Make it so...
Mike Hammond
Old November 28th, 2005, 12:03 AM
Update - talked to Mike H this weekend and we both agree that we are burning karma if we shaft AAA into moving a "derelict vehicle" instead of simply assisting after a breakdown.
My plan now is to call BWO and see if they are willing to roll up there with a truck and collect it (I've heard they have a PU and flatbed trailer). If Jesse is willing then I'll have him do the brake work and make it road-able.
If that is a bust, then you'll see me back on here in a day or so...
Old November 28th, 2005, 03:24 AM
JimC,
Doing a MC should take at most an hour if you have a second person to pump the pedal.
I have a spare front D/S in buffalo we can take as a spare (not sure if it is the right length, 84 might have the 4 speed LT95)
Battery we can borrow one.
P/S leaks are standard.
Worn box woop dee doo
Not too worried on the wheel bearings, easy fix with steel wheels
The rest can be ignored or topped up.
I am gung ho for this trip. Let me know if you want me to go or not. I would fly into buffalo where I will be staying with my parents for the holidays. Let me know asap and I will get the doors and stuff to fit in the new BMW to go with me up there. If mike wants to go solo, he has a place to stay night 1.
Ron
Battery missing
-Power steering leaks
-PS box mainshaft bad, box might just need adjustment
-Brake master damaged and needs to be replaced
-All wheel bearings slightly loose
-Both panhard rod bushings bad
-Rear pinion seal leak
-Rear transfer case output seal leak
-Rear crossmember shows some rust
-A arm link joint bad
-Driveshaft splines worn
-U joints worn
-Windscreen cracked
-Engine will not idle well, needs some choke to run smooth
Old November 28th, 2005, 09:43 AM
Ron if your in then lets make this happen! I have no problem with you coming along driving or whatever, specially if you bring a door or 2! I think I'll either cover the rear doors or put up the drop curtain it depending on the weather. I should be able to make it down to you with no front doors though
Old November 28th, 2005, 12:29 PM
Ron - I know the MC and other stuff is all gravy, but someone would have to drive to ECR and do the fixes there in order to drive it out. I figured the best way to do it would just have BWO take care of it so its not an screw-job for anyone else.
Also - were a go with Rob D's trannies and T-cases. Mike can just head to Cityside and load up whatever looks like it will fit in there without having the truck sit on its axles.
Old November 28th, 2005, 01:13 PM
Cool! I've never been to City side be good to find out where it is.
Old November 29th, 2005, 12:27 AM
I have all four doors. I need the glass and trim out of the rears and latches out of the front but they are light and can just throw them in the luggage. I dug them out tonight. They are ugly but they will keep most of the snow out. I will dig out some hinges too. We will have to strap the rears on as I do not have latches that will work on that truck. No biggie, I have bungies. The SIIIs three front doors should be fine with latches as an 84 it should have SIIIs style doors.
Anyway. If JimC gets me a ticket back to buffalo I am completely ready to roll. Tools, doors, a case of 90wt :-) mechanic's suit . . . sandals for cali!
Mike, if you can make it to buffalo (actually niagara falls 14305) without doors more power to you.
It is RIGHT on the way.
I am emailing you both my number now.
Ron
Old November 29th, 2005, 01:01 AM
The plane tix are cool, but I'm a little stymied on your return dates. We can take a guess, but if something goes amiss or you want to hang out somewhere and extend the trip then you're screwed. What do you guys think? I replied to Ron.
Old November 29th, 2005, 02:33 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I've got some extra hinges. They're rusted, ugly, and a little beat up (I dremeled 2 of them) but they'll hold the doors on. Tell me where to ship 'em if you want them.
"It's not a Jeep"
Old November 29th, 2005, 05:44 PM
We might need'em - ECR offered me some doors, but I dont know of the hinge status. Thanks for the offer, I'll let you know.
Old November 29th, 2005, 06:08 PM
JBurt's Avatar
JBurt
Jesse McCoy
Like I said, they ain't pretty, but at least 2 will hold the doors on...
"It's not a Jeep"
Old November 29th, 2005, 10:24 PM
If you can get doors from ECR that would be ideal as I will not have to lug mine to buffalo on the roof for the beamer. They should have a rusty parts truck to pull them off of. Take the hinges from Jburt too if ECR does not have some to borrow/steal. BWO might have some too. Lots of rusty doors in maine available you know
Check your email.
Ron
