I need help with the brake booster vacuum hose routing - Defender Source
Old August 30th, 2012, 12:52 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
When I drove my Defender (94 NAS ST) I bought for the first time after it was unloaded yesterday I immediately noticed something is wrong with the brakes. I opened the hood and discovered the vacuum hose to the booster is missing... Could someone perhaps help me out by checking to see how the vacuum hoses are routed and where it connects to the engine?
There is a hose on the opposite side of the engine (passenger side LHD) that's plugged with a bolt. Is this for the booster?
Also there's what appears to be a connection for something at the throttle body housing. Anything?
The Microcat diagram of the setup shows sort of a complicated routing with a vacuum tank (MUC1679). My truck has A/C (not functioning) but I could not find the vacuum tank. Do I need that? Would it be near the brake booster? The diagram does not show where hoses #3 and #8 go.
Name:	Brake servo hose _resize.JPG
ID:	56787   Click image for larger version
Name:	Brake servo hose 2_resize.JPG
Name:	Brake servo hose 3_resize.JPG
ID:	56789   Click image for larger version
Name:	Brake servo hose diagram.JPG
ac, boost, brake, vacuum
Quickest way to change a brake booster? Hoosier Defender Technical Discussions 1 May 13th, 2009 08:29 PM
cracked brake booster: interchange? jaherring Defender Technical Discussions 4 November 29th, 2007 08:33 PM
110 Heater Hose Routing newfD90 Defender Technical Discussions 11 February 1st, 2006 02:02 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
