I need help ASAP - Defender Source
Old October 5th, 2006, 12:40 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I need help ASAP
So i`m 20 miles away from home right this moment and my transfer case is stuck in neutral. it wont budge, at all, so the car wont move. Any suggestions? If anyone wants to call me at 650 346 6265 to help me out, that would be absolutely killer.
Old October 5th, 2006, 03:56 AM
oldscratchggf
nate
95 d90
T case is shot. I drove home on the freeway in low, it kicked ass.
Thanks to those of you who called me, I owe you.
Old October 5th, 2006, 08:25 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
sorry to hear it... If it is truly shot I think I saw one with a 1.6 low ratio at rovers down south website. This is lower than standard IIRC, check it out..
~Steve
Old October 5th, 2006, 02:47 PM
oldscratchggf
nate
95 d90
and stock is what, 1.2? Because i could get a LT230 with 10k miles on it for $300, and pay out the ass to have it installed.... but thinking about it, how easy/hard is it to install these t-cases?
Old October 5th, 2006, 03:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
the 1.6 is the high range not the low range... I would go with the $300 dollar one and install it your self.. its not hard just heavy and awkward.. take your center console off and the plate below it.. als the tunnel cover inside and you will see the bolts.. about 8 of them and the drive shafts.. I would rig up a jack with a plate on it. I made one out of plywood and 2x4's to support it in and out..
Legend in My Own Mind.
Old October 5th, 2006, 05:03 PM
oldscratchggf
nate
95 d90
So what is the 1.6 going to do for me? Wouldn`t that just slow me down? I`m running 33`s right now (planning on stepping it up to 35`s), with 4.10 gearing in the diffs. How would this all work together?
Fair price for sand blasting? JimC and evilfij need help asap evilfij Misc. Chit-Chat 18 April 1st, 2009 02:15 PM
Needed ASAP flippedrover Wanted 10 December 28th, 2007 04:36 PM
Need winch line in Denver ASAP! Quimbola Defender Technical Discussions 8 August 22nd, 2007 08:19 PM
Need a radiator asap! mlw911 Wanted 0 February 10th, 2006 01:31 PM
wanted bimini top for a 97 D90 asap bert Wanted 0 June 8th, 2005 10:48 AM
