I need a diesel guerue - Page 2 - Defender Source
Old April 9th, 2013, 11:23 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
There's only 1 wire to the injection pump. If you have a volt meter, turn the ignition on & check for 12v where it touches the solenoid. If no volts, (with the ign on) then check for a blown fuse.
Old April 9th, 2013, 11:28 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by dennis View Post
there's only 1 wire to the injection pump. If you have a volt meter, turn the ignition on & check for 12v where it touches the solenoid. If no volts, (with the ign on) then check for a blown fuse.
10-4
Old April 10th, 2013, 02:16 AM
The Gurus have it!
Old April 10th, 2013, 08:09 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Also make sure the little lever on the lift pump is in the correct position to allow it to pump. Along with power to the fuel stop you should hear it make a light click when power is supplied to the fuel stop.
Old May 17th, 2013, 06:07 PM
jafir's Avatar
jafir
Jafir Elkurd
Does this apply to a 2.5NA also? If so, what is the correct position?
Old May 17th, 2013, 10:08 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Curious about that too, jafir
Old May 17th, 2013, 10:15 PM
If the pump is on the cam the lever will not pump. You should feel pumping resistance. If you don't then rotate the engine a bit.
Old May 17th, 2013, 10:20 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I'm guessing that this refers to the position of the cam lobe relative to the fuel pump arm. If the arm is riding up on the lobe, the manual pumping lever will not be able to move the pump diaphragm.
John Karlsson
Hope Valley, RI
Old May 17th, 2013, 11:02 PM
jafir's Avatar
jafir
Jafir Elkurd
Okay. That makes sense. It also explains why nothing came out of the bleeder.
diesel
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Ex-MOD 2.5 diesel 90 EndlessEarth4WD Misc. Chit-Chat 18 January 26th, 2006 01:34 PM
Can you fab a diesel exhaust like a V8 exhaust? solihul Defender Technical Discussions 8 September 7th, 2005 04:09 PM
Defender 90 diesel engine and Electronics? x0054 Defender Technical Discussions 1 July 30th, 2005 10:43 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
