I need 8 fuel injectors - Defender Source
Old May 17th, 2015, 02:14 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
So I need 8 fuel injectors. I'm shopping online and finding prices ranging from $43/each to over $100. On a 1994 D90 ST NAS, Am I going to notice a difference between these products? Will the cheaper ones get the job done?
Can anyone recommend a brand/model that they suggest?
Thanks in advance! I'm in the home stretch getting my Defender back on the road after 5 years.
Old May 17th, 2015, 02:19 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Search here. Bosch injectors for the Ford 4.6l the 90s is a betterment over the OEM Lucas and 1/2 the cost on eBay.
Example (but I am not sure if the correct ones): http://www.ebay.com/itm/1993-1994-LA...fa8370&vxp=mtr
Old May 17th, 2015, 02:35 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks Russell!
Old May 18th, 2015, 06:57 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
When I did my 94 I put these in and they were great. Be sure to keep your old Lucas ones and the o rings. When I installed the rail the first time I pressed it down and then tightened. I ended up slightly pinching one and it leaked. The second time i had my dad help and we slowly tightened the rail down while making sure each injector was properly centered and it was perfect.
Old May 18th, 2015, 07:18 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I got mine from Five 0…. definitely more expensive than that ebay listing…. but just another option for you.
1994 LAND ROVER RANGE ROVER V8, 3.9L, 2, GAS Fuel Injectors
Old May 18th, 2015, 07:48 AM
Just get a set from ebay for $20. no need to spend more. Look for 19lb injectors from an 86-93 mustang.
Old May 18th, 2015, 07:58 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Thanks everyone!!
fuel
Fuel rail & injectors ini88 Defender Technical Discussions 0 November 1st, 2010 11:49 PM
Non-Lucas fuel injectors tgraham Defender Technical Discussions 1 July 21st, 2010 10:12 AM
fuel rail and injectors kolvedic Defender Technical Discussions 3 June 15th, 2010 04:31 PM
4.0 fuel injectors crobinson Defender Technical Discussions 3 January 17th, 2009 09:08 PM
fuel injectors not working matt Defender Technical Discussions 1 May 24th, 2007 06:28 PM
