I know zippy about the D's electronics big picture - Defender Source
Old August 31st, 2009, 07:38 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I need to replace my AC condensor fan. The ez thing to do is buy OEM but its also the most expensive option. If I use an aftermarket fan, or one from a disco or something, do I also run the risk of faulting something else down the line? I know zippy about relays and crap so I'd rather not try and save $275 on a fan if it's going to cost me $xxx doing it all over agin the "right" way.
Thoughts?
Old August 31st, 2009, 07:53 PM
I would go with an aftermarket one... There are several D90 guys in your area, ask them to help you.
Old August 31st, 2009, 08:38 PM
Clay there isn't a whole lot that you can do wrong. Make sure the replacement has the same ratings for the motor (amps drawn) and that it mounts well and there shouldn't be any difference. You can probably cut the connector off the old fan and not even modify your stock harness either.
Old September 8th, 2009, 08:55 AM
1of40's Avatar
1of40
1of40
Thanks guys! Sounds like it's in the no-brainer category which makes me more comfortable.
Picture of Door Check Strap mgrgpg Defender Technical Discussions 6 October 24th, 2005 08:39 AM
Picture needed! TwisteD90 Defender Technical Discussions 7 October 2nd, 2005 05:01 PM
Defender 90 diesel engine and Electronics? x0054 Defender Technical Discussions 1 July 30th, 2005 10:43 PM
Where do you buy electronics? jcasteel Defender Technical Discussions 8 January 2nd, 2005 04:44 AM
Big Dogs lobster Trips, Trails and Events 0 April 15th, 2004 01:34 PM
