i did a search, ecu code help - Defender Source
Old February 25th, 2007, 02:04 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
"Code 14 - Coolant thermistor
Refer to test 14, continuity test procedure."
Just finished up a head gasket job and this is the code my engine is throwing, any ideas on what that might mean?
Old February 25th, 2007, 07:51 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
yep, it's most likely the coolant temp sensor. There are two in the truck on the intake manifold. This would be the one that threads in from the top, not the one that threads in from the front.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 26th, 2007, 06:39 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
-Hans
interesting, i'll make sure the wiring is attached correctly.
I've noticed another problem though, after driving and getting the car warm when i come to a stop the car idles at ~2k, then after about 15 seconds it'll drop down to 1100 or so, i've tried adjusting the throttle cable a little, but would the code be thrown cause this issue?
Old February 26th, 2007, 09:57 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Stepper?
Jimmy Buffett
Old February 27th, 2007, 12:50 PM
Hans's Avatar
Hans
Hans Haase
If you've had the power disconnected lately, the RPM thing is actually normal and nothing to worry about. The computer just has to go through it's whole adaptive routine again to re-learn how your engine is performing. It will go away on its own eventually, but depending on how often you drive it may take a week or more.
-Hans
My oil line fix
Old February 27th, 2007, 01:35 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
-Hans
interesting, i did have the battery unplugged for 14 days, i'll keep that in mind... i'm still trying to trace down if i broke the cable, or if the sensor is bad, i'm leaning more towards broken wire though, i have to run a cunductivity test, also the engine is running a bit rough
Old February 27th, 2007, 09:00 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
just as a follow-up to this problem, i spent a little time trying to figure out what was going on and it turns out that the sensor on the driver side front of the manifold and the fuel injector for the front cylinder on the driver side have the same wirinng harness clip style, needless to say my brother assembled the driver side and i did the passenger, not that i probably wouldn't have made the mistake, but i labeled my half everything runs great though!
ps, thanks for all the help guys
Old February 27th, 2007, 10:57 PM
Hans's Avatar
Hans
Hans Haase
Yep, now that I think back (and after you mentioned it), I remember being worried about the same thing when I did my head gaskets a couple years back. I ended up putting a red wire tie on the fuel rail sensor connector, and a blue one on the coolant sensor connector.
Glad it's all good now, and glad it didn't cost much to fix.
-Hans
My oil line fix
ecu
Ecu Code 03 bjenk Defender Technical Discussions 12 January 23rd, 2013 11:25 AM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
