I.D. of various hoses on 300TDi? - Defender Source
Old June 29th, 2008, 05:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
Can anyone out there give me the ID of the fuel hoses that run to and from the engine mounted fuel filter on the 300TDi. I also need the id of the power steering hoses that run to and from the stock reservoir. I know I could just pull them but I would like to order them today and won't be able to get up to the truck for at least a couple days. Thanks.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 29th, 2008, 05:18 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
This probably isn't what you want, but I used AN-6 braided line.
Old June 29th, 2008, 06:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
On the PS or Fuel? It will help I think. Thanks.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 29th, 2008, 06:21 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Fuel. But rereading your original question, I used the AN-6 to and from the fuel tank. From the lift pump to the filter and from the filter to the fuel injector pump, I used stock. I should be at the shop tomorrow and I can measure if you wish.
Old June 29th, 2008, 06:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
That would be cool. If I remember right, they're just cheasy little plastic lines, but your saving me an extra trip. Thanks.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 29th, 2008, 07:00 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Correct stock is stiff plastic - I'll measure it and the PS line. Engine is out and in pieces, so it's easy
Old June 30th, 2008, 05:33 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Stiff plastic fuel lines - 0.310" OD and .050 (approx) wall thickness. = aprox 0.2" ID
PS Hose (reservoir to pump) - 0.625" ID
Old July 1st, 2008, 01:19 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I can look up the part #'s for you tomorrow afternoon.. I am at work now.
Legend in My Own Mind.
Old July 1st, 2008, 01:35 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks a ton man but it's all custom now. I need to make new stuff.
Thanks Hoosier.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 1st, 2008, 09:41 PM
It is 3/8" tubing (nylon most likely). No hoses are used. The tubing is a much better choice for fuel line than hose....
Old July 1st, 2008, 10:26 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Buck...
I KNOW that truck didn't have power steering way back when...you did that? My compliments.
Old July 2nd, 2008, 12:27 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by Gkase
Buck...
Thanks Red90. Can I ask why?
George! Good to hear from you. A lot has changed!! You want me to send you pictures of what your truck looks like as version 2.5?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 3rd, 2008, 12:50 PM
Fuel "hose" is normally an oil resistant synthetic rubber. It can be degraded by some chemicals like Biodiesel. If you use hose, try to find nitrile hose.
Nylon tubing is inert to any of the chemicals found in an automotive application. If you like overkill, you can use Teflon tubing which can also take relatively high temperatures.
Doing a bit of research... Nitrile may or may not be suitable for Biodiesel depending on brand...
Old July 3rd, 2008, 01:42 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Cool thanks. So if I have no intention of using Biodiesel, I am cool with a standard fuel hose?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 3rd, 2008, 04:45 PM
Sure, but as stated, all the stock fittings are based around tubing.
As to PS, I believe 1/2" and 5/8".
Old July 3rd, 2008, 04:51 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You rock, Thanks
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 4th, 2008, 10:20 AM
Correction, the PS is 3/8" and 5/8". Just checked the hoses I bought to do mine.
300tdi, tdi
Cutting off heater hoses on 300Tdi... JFD Defender Technical Discussions 4 September 20th, 2006 09:11 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
