Hypothetically - Should I Worry? - Defender Source
Old March 20th, 2009, 10:27 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
350 miles from home, 50 miles from the nearest civilization(?) and the CHECK ENGINE light comes on. No, I do not have one of those gizmos that gives you a code read out (wouldn't know where to plug it in anyway) nor do I have a decoding ring to tell me what the code means. After relaxing with a cold one, what should I do?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old March 20th, 2009, 10:29 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
on a '94, the code reader is by the passenger foot well (by passengers right foot), it should display the code in bright red LED characters... try to find that, then tell us what it says, and we can help you further.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
You dont need the reader since your truck is OBDI. Im not sure where the display is on the 94's i think it might be under the dash.
www.troublecodes.net has a list of OBDI codes, Ill bet its the stepper motor. mileage?
Old March 20th, 2009, 10:38 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
See if it was an intermittent issue. Rest the unit by disconnecting the battery for a couple of minutes. Once you do this, you display box will show 02 (power disconnect) until you have run for a while.
Old March 20th, 2009, 10:42 AM
No, but pull the box out and look at what the code is.
Old March 20th, 2009, 11:19 AM
Easier way to reset the codes is to turn the ignition to on, then disconnect the ECU for a few seconds, then reconnect. You'll get a 02, the first start which is expected.
Old March 20th, 2009, 11:37 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Disconnect battery - resets computer (and radio )
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
gear ratio change??? punter Defender Technical Discussions 19 August 29th, 2007 09:26 AM
Moving to Utah chris snell Defender Technical Discussions 12 January 13th, 2006 12:01 PM
