hypermiling with a vacuum gauge for diesel? - Defender Source
Old July 25th, 2007, 12:32 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
First, does anyone know if a vacuum gauge would work on my 300Tdi like it works on petrol engines to determine "mileage". In other words is there the same kind of relationship between vacuum and fuel usage in a diesel as there is in a gas engine? If so, where would you tap into the vacuum?
The reason I ask is a new experiment in going for even higher miles per gallon with my 300Tdi than the 28mpg I'm currently getting. I recently bought a Honda Insight hybrid as a commuter car and am getting around 60mpg out of it. The interesting thing about driving the Honda is how much I'm learning about the world of "hypermiling"...there are websites devoted to getting incredible mileage out of rather ordinary cars not just hybrids...like 50mpg out of a Saturn sedan for example. Anyhow, it struck me that some of this rather geeky knowledge I've been discovering could be ported to our trucks. The "pulse and glide" driving technique, higher tire pressures, and so on...
anyway, if you know about this vacuum gauge thing, I'd be interested to hear.
Old July 25th, 2007, 07:11 PM
pendy's Avatar
pendy
jim pendleton
89'd90
You could lower your D90 to get the hiper mileage.
Saabs run a vacuum/boost gauge on their Turbocharged vehicles. Very rarely does it go into the vacuum though. I do not think this will help your efforts for more mileage.
JP
legend in my own mind
Old July 25th, 2007, 10:15 PM
Monkeyboy
Guest
Posts: n/a
Just remove that pesky turbo thingamajiggie and you too can have manifold vacuum.
Old July 25th, 2007, 11:30 PM
Put a food processor on your Delorian and then connect it to the flux capacitor...oh, never mind, wrong forum.
ac, diesel, vacuum
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
