Hydraulic winches - Page 2 - Defender Source
Old December 25th, 2010, 04:29 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
you won't break a thing.
if you slip into neutral or engage the clutch the pump will simply stop and so will the winch.
once you engage back into gear, 2nd or 3 rd or 4th, the pump engages again, albeit faster, and you're on your way.
there are no sudden stops or starts.......think of it as an auto tranny..........there is NO "mechanical" connection between the pump on the transfer case and the winch itself......it's essentially connected via the hydro fluid.
when i engage the pump there is no "feathering" of the throttle unless you are "driving". if you only want to engage the winch you just pop in gear as there is no resistance to the pump.
winch
Found another hydraulic PTO option.... Hans Defender Technical Discussions 2 April 1st, 2010 12:13 AM
MileMarker hydraulic winch purchase & setup aclarke Defender Technical Discussions 21 March 10th, 2007 02:17 PM
Hydraulic PTO for sale 90/110 k4rovers For Sale - Parts 6 August 30th, 2006 07:31 PM
Milemarker Winches? gtg067i Defender Technical Discussions 28 April 15th, 2005 07:21 AM
Maxi-Drive Hydraulic PTO Info Hans Misc. Chit-Chat 2 February 19th, 2004 06:40 AM
