Hydraulic winch underpowered??? - Defender Source
Old December 18th, 2012, 10:26 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Finally got around over my vacation time to get my hydraulic winch all buttoned up but when I went to try it, it seemed super weak. I can stop the drum with pressure from my fingers. I checked all the lines and there are not any leaks, so I am wondering is there air getting in the lines preventing a complete fluid flow..??? and if so how would I check for this because if air was getting in, that would be in the suction from the tank to the pump line.
Any ideas of what to check would be appreciated!
thanks in advance
Old December 18th, 2012, 10:37 AM
sounds like a restriction somewhere. are you tapping into the power steering pump for pressure ?
Old December 18th, 2012, 10:39 AM
USLandy's Avatar
USLandy
Andrew
defender 90
No, running a engine mounted pump where the aircon usually is. I do have an Engine mount OCV mounted. May need to adjust that. Its all redwinch gear, got the challenger and the engine mounted pump.
Old December 18th, 2012, 11:40 AM
carlosz's Avatar
carlosz
Carlos
are you turning enough rpm's @ idle?
Old December 18th, 2012, 01:04 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Yea, tried that still no luck.
Old December 18th, 2012, 01:36 PM
Assume fluid flow is in correct direction and flow/PSI of pump is fully present and correct. That leaves me with potential for a blockage in a line or some defect in the winch itself
Old December 18th, 2012, 01:45 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Is the pump variable pressure or constant pressure with a pressure regulator (bypass valve or circuit). It could be a faulty bypass or an internal bypass thru faulty seals of the pump or hydraulic motor.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old December 18th, 2012, 02:55 PM
LRover's Avatar
LRover
J. Michael McCaig
Some things to check - Is the pump clutch fully engaged? Is the control valve opened fully to the motor? Is the relief valve stuck open? Is the winch in gear?
winch
Identify this hydraulic winch aclarke Defender Technical Discussions 0 December 10th, 2007 09:32 PM
MileMarker hydraulic winch purchase & setup aclarke Defender Technical Discussions 21 March 10th, 2007 02:17 PM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
