Hydraulic Tank - Defender Source
Old August 16th, 2013, 09:22 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Hydraulic Tank
I'm gathering bits to install a hydraulic winch on my ROW 90. One issue I haven't worked out is what to use for a hydraulic fluid reservoir and where to mount it. RHD 90 with fuel tank under RH seat and battery under LH seat. Suggestions?
John Karlsson
Hope Valley, RI
Old August 17th, 2013, 06:13 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
If you intend to use it for long haul, then you might need a cooling reservoir, otherwise, pump line winch and use the same type of reservoir as the power steering. I'm sure you can find a spot right next to the one already in place.
Old August 17th, 2013, 06:53 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Since your fuel tank in under the seat you could install it like in the SIII.
The tank is mounted in the rear against the rear cross member. An access hole is cut in the wheel arch and a cover plate fitted.
Be sure to fit an over center valve if your motor doesn't have one.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Land Rover series rare PTO with hydraulic tank and pump airbornrover The Flea Market 0 March 26th, 2011 11:09 PM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 04:05 AM
Aux tank and LR winch bumper Jase For Sale - Parts 10 July 1st, 2005 06:38 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
Dropping the gas tank Gkase Defender Technical Discussions 33 December 1st, 2003 08:59 AM
