Hydraulic Lifters - Defender Source
Old November 3rd, 2011, 09:04 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Hydraulic Lifters
What does your engine do or sound like if one of your hydraulic lifters is bad?
Has anyone had a lifter or lifters go bad?
Firemanshort
1980 Stage One 109
Sterling, VA
Old November 3rd, 2011, 10:26 PM
Rugbier's Avatar
Rugbier
Gustavo
should sound like an old low compression engine ( picture a Ford A )
NO SIGNATURE
Old November 3rd, 2011, 10:33 PM
carlosz's Avatar
carlosz
Carlos
a continous rithmic tic somewhat similar to the arc of a disconected spark plug wire, or the tip of a pencil striking a table top in a rithmic fashion.
if you have ever paid attention to your engine during the first seconds after being started following an oil change or sitting for a week... that "loose metal rattle" is all the lifters charging.
Old November 4th, 2011, 08:51 AM
Firemanshort
David Short
1980 Stage One 109
Can I fix by just replacing the bad lifter or do I have to replace the whole set / do the whole cam break-in procedure and so forth?
Firemanshort
1980 Stage One 109
Sterling, VA
Old November 4th, 2011, 11:50 AM
Grover's Avatar
Grover
If your in there, replace the whole set.
Old November 4th, 2011, 07:35 PM
If its ticking have you check the manifolds? Also marvel mystery oil is worth a shot, what oil are you using? Lifters are a big snowball, it becomes "while Im in there I might as well replace" projects.
Old November 5th, 2011, 01:49 AM
DefenderPilot
George
1997 D90 SW
It sounds like a clatter noise but you may have worn rockers as well where the push rod hits is very common on Rover v8s. Im planing on changing the lifters and rockers to Iskenderians soon.
Hydraulic Dampner D90DRC Defender Technical Discussions 0 June 12th, 2010 03:38 PM
MileMarker hydraulic winch purchase & setup aclarke Defender Technical Discussions 21 March 10th, 2007 02:17 PM
Hydraulic PTO for sale 90/110 k4rovers For Sale - Parts 6 August 30th, 2006 07:31 PM
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Maxi-Drive Hydraulic PTO Info Hans Misc. Chit-Chat 2 February 19th, 2004 06:40 AM
