Hybrid build question - Page 2 - Defender Source
Old May 23rd, 2012, 01:43 PM
The Dro
Dro
1988 Ninety
Jake,
You should be able to use the smaller glass from the 2nd row door and weld the back pillar.
I cannot find for the life of me an Aussie site that did this.
Old May 23rd, 2012, 01:48 PM
The Dro
Dro
1988 Ninety
I don't have Photoshop or any fancy software.
I remember the guy cutting the rear and welding it to where you cut yours.
He used the rear door and kept the interior wheel wells with the floor panel.
Old May 23rd, 2012, 02:01 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea I'm not really a fan of reusing the rear of the truck I think it just looks a little bit too goofy - as if it doesnt look goofy enough already... Plus all of that is really heavy and where it's cut up would require just as much work to fit it as it would take to just weld in a couple pillars and use sheet metal.
I will probably do the sheet metal in panels which is what the cross sections are for. I have pics from another build where a guy used one huge piece of sheet for the whole thing and just riveted in like the pics attached. I think Charles idea of getting the sheet off a truck in a scrap yard is a good idea.. Get it done like that - add some paint and a little plexi glass rear window and good to go!
ID:	52052   Click image for larger version
ID:	52054   Click image for larger version
Old May 23rd, 2012, 02:26 PM
The Dro
Dro
1988 Ninety
It looked like this:
defender 110 build chassis question zdover Defender Technical Discussions 11 January 19th, 2011 01:50 PM
WTB D90 body parts - Considering a hybrid build. Roving Beetle Wanted 15 February 26th, 2010 12:19 PM
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
New project hybrid question phoenix37 Defender Technical Discussions 4 August 2nd, 2008 06:21 AM
