Husky 10 with Warn Remote?? - Defender Source
Old March 24th, 2005, 01:32 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
I heard somewhere that it was possible to hook up a Warn remote control up to a Husky 10 winch.
Has anyone done this? I have the older style Husky remote control which I am about to replace because it is broken and I want to consider my options.
I understand the Warn remote is nicer and Superwinch actually imitated the Warn style a little bit on their newer remotes, which are not compatible with the older style solenoid box/remote control of the Husky 10.
Or did I just imagine all this? It happens occasionally.
Jay
Old March 24th, 2005, 01:41 PM
If you cut the connector off of one your old Husky I am sure you can use a warn switch if you splice the cable, do you have a pic of what the connector on the husky looks like?
Old March 24th, 2005, 02:53 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
contact John at expeditionexchange.com he can help you.
Old March 24th, 2005, 02:54 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
I was too general before... The connector on the husky control has a failed pin (half of it has broken off), so i have to fiddle with the connection for the winch to work... so the real soln i guess is for me to buy the new husky connector part alone if that is possible.
I haven't seen what the connector of the Warn looks like, but here are some pics of the older style Husky.
It would be nice if I could find a way to use a better style of remote.
Name:	Controler1 (Custom).JPG
ID:	2820   Click image for larger version
Old March 24th, 2005, 03:11 PM
The connector looks different then a Warn, so yup you need to replace the connector.
Old March 25th, 2005, 09:51 AM
Troys
Troy Smith
1995 D90 SW
I had the exact same problem with my remote that came with my S9. The pins are definately the weak link. They can easily be repalced. I purchased new pins at a local HW store and replaced. I also bought a Heady Duty remote that Superwinch offers. Definately worth the money!!! Now I carry two remotes. I use the HD one and use the original as a back up.
Troy
Old March 25th, 2005, 03:13 PM
PUll out old plug off husky.
BUy warn plug.
Swap in (note I mounted mine remotely and I do not know it it will fit on winch).
Connect three wires.
Done.
Warn remote control of husky
Old March 31st, 2005, 07:56 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
Appreciate all the feedback fellas.
I just got off the phone with the Superwinch techs because I was having a hell of a time finding the right pin for a replacement... long story short...
Superwinch now sells their Heavy Duty (Warn Style) remote with the old style plug... $49.
If you are looking for replacement pins, they will send some to you for no charge as well.
remote
Warn Wireless remote to a 3 wire winch Help Hammertime Defender Technical Discussions 4 October 26th, 2009 02:57 PM
Warn winch Wireless Remote Rugbier For Sale - Parts 1 May 31st, 2009 04:12 PM
Husky 10 and steering Tim Scully Smaller Projects 2 December 13th, 2008 04:56 PM
Warn remote Overlander Wanted 2 June 8th, 2007 09:07 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
