Hunter front calipers? - Defender Source
Old July 4th, 2015, 04:59 PM
Abrooks's Avatar
Abrooks
Tony Brooks
In the midst of a full brake job on the '91 hunter. It appears likely that the front brake calipers should cross to the pre-1990 non-abs trucks vs. the 1991 abs calipers. Can anyone confirm this to be the case?
Old July 4th, 2015, 06:06 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks Jeff. I ask as I found mention that there may be a mod necessary to the caliper if you're converting abs to non (connecting the piston bores internally). As well, there are separate part numbers for abs trucks and non. But that does seem like a lot of over thinking of what rover engineers were capable of.
Old July 5th, 2015, 12:44 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I think it's more about vented vs solid rotors. Which does the Hunter have?
Old July 5th, 2015, 01:13 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
1991 is vented; Non-ABS
I believe the '89 Hunters are the skinny solid rotor...
I just replaced my 1991 Hunter front calipers with some from Zack at RN.
Used to be able to find them at Advance and NAPA a year or 2 ago....not any more.
Rent my
Old July 5th, 2015, 01:54 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yup, vented. Do you remember if it was the same p/n for abs and non abs?
Old July 5th, 2015, 02:43 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I still have the boxes and part #s.
"Hunter & ABS"
I got the RN Proline version as that was the only thing available.
Very good so far.
I put these on back in December '14.
Rent my
Range Rover Hunter :: 1991 Land Rover Hunter Nomar Defender & Series Truck Registry 2 April 30th, 2014 02:15 PM
Hunter :: 1991 Land Rover Range Rover Hunter Edition andy110 Defender & Series Truck Registry 0 March 10th, 2014 01:16 PM
Troll Hunter kevkon Misc. Chit-Chat 3 May 24th, 2011 10:35 AM
1991 Range Rover Hunter Abrooks For Sale - Vehicles 3 April 17th, 2008 07:05 PM
1989 Range Rover Hunter pcarey For Sale - Vehicles 1 November 3rd, 2003 01:12 PM
