Hump or no hump is the question - Defender Source
Old August 27th, 2015, 12:37 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Can anybody with a LT77 gearnox tell me if your seat box has this bracket that my finger is pointing to. Exmoor trim say only the R380 seat box is this way,
There two differant seat box acoustic mats for the Defender with the hump for the bracket (R380) and flat for the (LT77)
I do not think that's true
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 27th, 2015, 01:12 PM
Photo of your transmission tunnel would be great. I suspect you have the LT77 set up unless its been modified.
There are two different accoustic mat set ups. The Transmission tunnel determines the type you need.
Old August 27th, 2015, 01:13 PM
The Dro
Dro
1988 Ninety
No pic
Old August 27th, 2015, 01:15 PM
simple, is your trans tunnel fiberglass or metal ? They aren't interchangeable the seat box flanges are totally different.
Old August 27th, 2015, 01:33 PM
roverman2010
1985 LR 90 200Tdi
Ok t
Do over, I have a metal tunnel with a LT77 as fitted as from Solihull
It's that bracket on the top middle of the seat box I am asking about.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 27th, 2015, 01:35 PM
I have no idea what you're talking about, but if you mean the raised square-edged lip at the front top of the seatbox, I have one on my LT77 seatbox.
My trans tunnel is metal.
Old August 27th, 2015, 01:39 PM
roverman2010
1985 LR 90 200Tdi
That's the one, according to Exmoor Trimthat's a R380 sit-up. Bunch of Boneheads. So if you want a Exmoor/Wright off road seat box cover and you have that lip you need a R380 cover????????
If only life was that simple
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 27th, 2015, 03:09 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
No you need the lt77 cover. It is marked on the bottom side for cut out. Atleast it was on mine.
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 27th, 2015, 03:30 PM
roverman2010
1985 LR 90 200Tdi
You mean to say you cut that section out?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 27th, 2015, 04:48 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
i did not because I have the v8 seat box with a 4cyl lt77 conversion. But the markings were there to cut it out. Once you do that the metal hump that you are talking about protrude through.
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 27th, 2015, 06:49 PM
Ignotus
gene
1960 109, w/200TDI
It's easy to tell an R380 apart from an LT77 - reverse on an LT77 is to the left of 1st and forwards - on a R380 it's behind 5th.
HTH
Gene
1960 109
1960 88 Ignotus
Blog;
Old August 27th, 2015, 07:44 PM
roverman2010
1985 LR 90 200Tdi
YES that I know, what the question was, do all defender seat boxes have that bracket/square tubing thing on the top middle front of the seat box as in the picture.
Exmoor trim say the R380 models have it, which is a crock of shite!
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 27th, 2015, 07:47 PM
roverman2010
1985 LR 90 200Tdi
Picture in question
What the finger is pointing at
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old August 27th, 2015, 09:23 PM
I don't think I've ever seen a Defender seatbox without that front lip thing.
Someone like Doug would be a good reference since he's seen so many Defenders.
I know for sure that series seatboxes don't have the lip.
Old August 28th, 2015, 11:24 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
All four cyl boxes have that lip. Eight cyl boxes do not. You are correct you need the lt77 mat and there is a mark line on the bottom side to cut it out. Looking at the pictures when i ordered mine it looked like the older lt77 mats had the hump molded into it.
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 28th, 2015, 11:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Ignotus View Post
It's easy to tell an R380 apart from an LT77 - reverse on an LT77 is to the left of 1st and forwards - on a R380 it's behind 5th. HTH
But you can have an R380 with a LT77 seat box.
lt77 trans hump Uncle Douglas Wanted 2 June 9th, 2014 09:49 PM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
28th Annual Hump N Bump 7&8 Nov 2008 - Las Vegas BCR Trips, Trails and Events 4 December 11th, 2008 06:59 PM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
