Hubs- Can nothing be easy with this truck? - Defender Source
Old December 2nd, 2006, 03:42 PM
punter
1966 Series IIA
Angry Hubs- Can nothing be easy with this truck?
Trying to disassemble the hubs on my Defender...
The brake drum is off; hub cap is off; the circlip has been removed; the six bolts retaining the driving member have been removed...
According to the shop manual, I'm supposd to be able to remove the driving member and joint washer... but I can't get the thing off.
There is no mention of any special tool necessary or any particular process required to get it off.
Anyone have experience with this?
Punter
Old December 3rd, 2006, 10:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Did you take the c lip off that is behind the plastic cap?
Legend in My Own Mind.
Old December 3rd, 2006, 05:13 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Screw driver or pry bar will usualy help get the drive cap off.
Jimmy Buffett
Old December 3rd, 2006, 09:20 PM
punter
1966 Series IIA
Yes, I removed the Circlip (the clip behind the cap).
I can't get a screwdriver or prybar between the two parts (the Driving member and the Hub) to pry them apart.
Old December 3rd, 2006, 09:35 PM
I have done this several times, but I cannot figure out where you are stuck... Would you be able to post a few pictures? We can then provide better advise.
Or bring it down to ATL, and I will help you fix it. :-)
Old December 4th, 2006, 07:52 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Does it wiggle at all or is it siezed to the hub?
Old December 4th, 2006, 08:17 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
Drive member = flange?
If so beat it sideways a tad with a rubber hammer.
Gently.
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old December 4th, 2006, 09:35 AM
Cube II is correct other than you may need a 3lb sledge and a good wack.
Old December 4th, 2006, 10:25 AM
Cube II's Avatar
Cube II
Michele
1997 D90
3 lb sledgehammer
[THOOOM!]
Michele
D90 VNTdi
[O]===[O]
Old December 4th, 2006, 04:51 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
if that doesn't work, I guess you could take the six bolts out, put the wheel back on, drop it off the jacks, throw it in low range, unlocked, hold the foot brake and give it some gas while in gear. Never tried it but that HAS to knock it loose. Last resort of course.
Old December 4th, 2006, 05:00 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wack the axle end with a sledge a bit but put a block of wood between it.
Old December 4th, 2006, 05:32 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Punter
That's a '93 110, right? And you are working on the rear axle, correct?
What workshop manual do you have? [I have the NAS paper manual at home and can look at it tonight in case this is not what you are already looking at]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 4th, 2006, 05:38 PM
Pull off the entire assembly at the tube and convert to discs :-)
Old December 4th, 2006, 07:35 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
x2....
Old December 4th, 2006, 08:20 PM
punter
1966 Series IIA
Nope... '84 Defender 110 ...but, yes, I am working on the rear.
The workshop manual I have is for '84-90
It and the hub wiggle a bit together... but it is siezed to the hub completely.
THAT is the intention... but I've got to get the old parts off to take some measurements for the fabricator.
I've been talking with Blackbird about the conversion... do you know of anyone else who does it?
Originally Posted by Cube II
[THOOOM!]
LOL!
Old December 4th, 2006, 08:33 PM
D90user's Avatar
D90user
steve
I'm not sure about the 84 axle, but you can buy the parts and bolt up the disks... somewhere on this forum is a parts list that has everything you need to do the conversion yourself. try searching for it.
Have you tried putting the wheel back on a spinning it (while still jacked up) to break the seal so that mabye you coudl fit the head of a skrewdriver in between the flange?
Also isn't the end of the axle threaded (hole)? could you put a bolt in there and make soemthing to pull on it with?
Old December 4th, 2006, 08:41 PM
punter
1966 Series IIA
Whoo Hoooo!!!
Well, it took a couple good wacks (sideways) with a small sledge and block of wood, but it came off and no parts appear to be damaged.
Although it appears as though the previous owner used a hammer and chisel to tighten the outer lock nut (rather than a wrench)... not sure how I feel about that.
Will do...
The only complication that I can forsee is finding some sort of bracket (that would bolt on the axel), to mount the caliper on. This is teh part that I've talked with Backbird about manufacturing (they've done it for a number of other rear axels).
I'll do a search, though, and see what I can turn up.
Thanks to all for the help.
Cheers,
Punter
Old December 5th, 2006, 09:38 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
call RTKeith
Old December 5th, 2006, 10:00 AM
The caliper bracket is a factory land rover part that appeared on the first disc salisburys before they cast in the bracket . . . .
Also check Pirate4x4.com Keith posted the stuff there too.
Ron
Old December 5th, 2006, 12:34 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Here's the thread: http://www.defendersource.com/forum/...0&postcount=27
The bracket is a LR part, but we had to machine .1" off of it to get the calipers to clear the rotors.
Keith@RT can get the brackets for you (that's where I got mine).
Chance
1994 Yellow NAS D90 - Canadian Truck FS DonFromWhitby For Sale - Vehicles 1 November 16th, 2009 03:24 PM
Yet another Truck Wont start... arbik Defender Technical Discussions 12 September 21st, 2006 03:51 AM
Finally Joe P Misc. Chit-Chat 68 September 4th, 2006 05:52 PM
Replacing Fuel Filter...Should be easy right? Antonios Defender Technical Discussions 5 January 5th, 2006 09:38 AM
Want a Project Truck Brent Nevin Wanted 8 June 29th, 2005 02:28 PM
