Hub Socket - Defender Source
Old August 25th, 2009, 03:12 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
Hub Socket
I am getting ready to do rotors and can't seem to locate a 52mm hub socket anywhere. Will a standard 6 point 52mm socket work?
Don't want to pull it apart until I know I have the right socket.
Old August 25th, 2009, 03:27 PM
a six-point 52mm socket is fine, but most of those come in a 1-in drive, which is pretty inconvenient. I ordered one from dingocroft in the UK since so I could get a 1/2-in drive - so I could either use a torque wrench or an impact wrench depending on my needs...
I think a 2 1/16 -in socket also works as well. They're kinda hard to find though.
Old August 25th, 2009, 03:30 PM
chrisconnie
Adam Hairston
97 LE #127/300
I can get a 52mm socket but I didn't know if it would work. Now I need to check on the drive size.
2 1/16th is the SAE cross over size but equally hard to find.
THANKS for the quick reply.
Old August 25th, 2009, 03:47 PM
If you order a LR tool, make sure you don't get the disco II/p38 socket. Its different.
Old August 25th, 2009, 03:48 PM
They are around $20 or less from Atlantic British... I would think a normal socket will be too thick to fit in the hub.
Old August 25th, 2009, 03:52 PM
chrisconnie
Adam Hairston
97 LE #127/300
Just ordered from Atlantic British for $20. It uses a screwdriver in the end so I won't need a 1 in. driver.
Thanks all!
Old August 25th, 2009, 07:38 PM
We have some big sockets to work on the drill with, it fit.
Old August 25th, 2009, 07:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have one that you can have. I don't need it anymore (yay!!).
If you can't find one let me know.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Good to know I guess. I wouldn't have thought one would have fit. There's not much room.
Old August 26th, 2009, 12:17 AM
chrisconnie
Adam Hairston
97 LE #127/300
Much appreciated Buck...got one on the way.
Old September 1st, 2009, 12:10 AM
chrisconnie
Adam Hairston
97 LE #127/300
Thanks all for the guidance. New pad/rotors, seals, wheel bearings repacked. Bout 2 hours per side. Sure beats the quote I got from the shop!
Old September 1st, 2009, 09:00 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
CruiserOutfitters.com
"Lockers" page - 1/2" drive, 2 1/16" hub nut tool. The pre-'95 FJ40-80's had the same size hub nut.
Price - $16.50.
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 05:26 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
What size socket? kit Defender Technical Discussions 1 February 7th, 2004 02:26 AM
