hub removal and grease - Defender Source
Old August 19th, 2014, 05:23 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
According to a dealer service sticker, the passenger side swivel joints have been injected with STC 3435 grease. Looking at the disassembled unit, I assume this grease is more viscous than regular grease, more "runny" but not certainly not as smooth flowing as gear oil?
Also, I know this has been debated ad naseum but should I clean out and refill with gear oil instead of swivle grease when putting the assembly back together? Can the swivel joint be serviced and completely cleaned in the manner shown in the pic, without having to go around and disassemble from the other side (i.e. the side of the hub disc facing the axle)?
Anything else? Degrease and re-lubricate the CV joints while I'm at it?
Old August 19th, 2014, 05:30 PM
CaptMidnite
Daniel Choi
By the way is the cv joint supposed to be all mucked up like that? Is something leaking?
Old August 19th, 2014, 06:01 PM
One Shot = EP00 Molybdenum Disulfide grease. This you can get in natural and synthetic at a number of sources. The LR stuff is simply packaged pre-measured. It's nuttin special. Also known by its NGLI number which is also 00.
Old August 19th, 2014, 06:53 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
That grease looks pretty good to me---I'd slap it back in, add a little more grease and call it done.
Doesnt look to be any water in there...
Almost forget; Briggs mentioned adding a few cc's of this lube to the one-shot for better fluidity...
http://www.astroglide.com/home.aspx
Rent my
Old August 19th, 2014, 10:43 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Yeah, just shove it in the hole with your finger then put the plug back in.
Old August 19th, 2014, 10:45 PM
it's no surprise to me that Briggs would be mentioned in a thread that comes to this.. he nasty
Mark Kellgren
KM4BOR
Old August 20th, 2014, 01:31 AM
All I said was Lube = Love. You guys are the ones that misinterpret.
-Jeff
I thought you said I was alright, Spider.
Old August 20th, 2014, 08:43 AM
87 D110 (Ruby)
You know Spider, you're a fuckin' mumbling stuttering little fuck. You know that?
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
Lucky8's Quick and dirty swivel ball grease install Fivespddisco Smaller Projects 3 January 3rd, 2013 09:02 AM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
leaking grease jimmy salmon Defender Technical Discussions 16 January 11th, 2007 09:55 PM
