hub rebuild - Defender Source
Old April 12th, 2015, 02:52 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
hub rebuild
Rebuilding the front hubs, need some tips on adjusting setting the end play.
Do I need bracket R0530106 (and a dial indicator) to measure it, or is there a generic setup that'll do the job. Recommendations? Looking for a home mechanic quality/price tool.
Anyone get away with just adjusting by hand (erring on the side of loose not tight) and re-assembling the hub?
I did some research and many seem to do it by "feel": Tightening Lock Nuts on Wheel Bearings
I'm leaning more towards following the manual step by step.
edit: Harbor Freight seems to have a clamp-on dial indicator for $35 that may do the job . . .
Old April 12th, 2015, 03:58 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Do it by feel.
Everybody does it that way.
watch him do it
Rent my
Old April 12th, 2015, 04:43 PM
The later manuals actually use a small preload and no end float, which is a better method. Just read the later manual and follow it.... Same as every other car in the universe.
Old April 12th, 2015, 06:25 PM
CaptMidnite
Daniel Choi
True, I'm a big stickler for following the factory manual and procedures. But often with older cars sometimes the collective wisdom of long term owners develops a slightly different procedure for doing things that may save a lot of money or time, or just make better sense.
For example, the LR manuals don't mention upgrading the oil cooler lines on the NAS V8's , but everyone does it.
Or, the early 2000s Porsches had a notoriously weak IMS bearing, which led to aftermarket fixes not officially endorsed by Porsche. (Google "Porsche IMS bearing failure")
Me personally I try to follow factory specs and procedures but just presenting the other side of the coin.
rebuild
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Hub nut! TwisteD90 Defender Technical Discussions 22 September 28th, 2004 02:00 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
