Hub Question - Defender Source
Old February 29th, 2012, 06:08 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Hub Question
I pulled the cv and stub axle on the left and am replacing it with an aftermarket HD AEU2522 style joint. So you can see where the wheel bearings ride is wider on the one I am trying to install.
Now I am pretty sure I can use early range rover 10 spline hubs on this stub axle as well. Who can tell me more about the difference in hubs/stubs and what years I can use? Will it work with all hubs that use the thicker 5806 style drive flange?
THANKS!!
Old February 29th, 2012, 09:17 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
88 and older RRC with teh mushroom caped axles.
-Jeff
Thanks Jeff, any idea on a part number for this?
Old March 1st, 2012, 08:46 AM
LRover's Avatar
LRover
J. Michael McCaig
hope this helps...
Old March 1st, 2012, 09:58 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Originally Posted by LRover View Post
hope this helps...
It does help me find the part number but I was also trying to see if I could use one of a RRC. My search has shown a different part number on like every website and the pre RRC have the bigger flanges but the stub axles look like the smaller version...
I am looking for a pair that have 1 1/4" spacing between the bearing races... Jeff if you have a pair and would be willing to sell them cheap and ship let me know
Thanks guys
Series III hub question Turbofan Series Technical Discussions 17 February 5th, 2012 07:42 PM
'Wet' hub question D90user Defender Technical Discussions 1 August 27th, 2007 07:05 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
