hub nuts - Defender Source
Old March 13th, 2005, 10:25 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
hub nuts
Just doing my rear wheel bearings,got every thing apart and found the outer bearing had disintergrated
also the lock nut and hub adjusting nut had both shatterd,what i want to know is,are these two nuts the same
Old March 13th, 2005, 01:01 PM
Yep, the nuts are the same.
Old March 13th, 2005, 06:00 PM
Jimmy! I'm right up the road! Call me!
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 05:26 PM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
