Hub nut! - Page 2 - Defender Source
Old September 27th, 2004, 07:45 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Mike, that was classic
JP, I'm running the prototype 110 CV's with different heat treat than the others (Third season on those bad boys with all the abuse they can take) and I think I'm using the same spindles but I could be wrong.
World traveler
Old September 27th, 2004, 11:19 PM
redrover
Guest
Posts: n/a
Yah john after I posted i remembered the key groove. JP
Old September 28th, 2004, 02:00 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Well unless the washer tab gets sheared off, the nuts still can't rotate.
I thought about the seals not being properly recessed, too, but it sounds like they've been tightened enough by now.
If the nuts ain't turning, the only way things can get loose is by the bearings changing their geometry. If this is the case, they're being overstressed; the hub design really isn't up to the loads being put on it. Wheel offsets especially put tremendous stress on hubs and bearings.
front hub nut size? tkavan01 Defender Technical Discussions 11 May 22nd, 2006 06:06 PM
hub nuts jimmy salmon Defender Technical Discussions 2 March 13th, 2005 06:00 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
