Hub leaking from center - Defender Source
Old March 25th, 2009, 12:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
I am about to replace a hub seal on my front wheel. I ordered a seal kit for all of 8 bucks from Roversnorth. While I was at it I ordered a new center cap for one of my rear wheels. Long story short I came out of work yesterday and the rear wheel was draining out the center. Easy fix? What do I do? I am assuming the rubber cap isn't going to seal it.
http://www.flickr.com/photos/barryri...43058/sizes/o/
Old March 25th, 2009, 12:32 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
The rubber cap will seal it.
I broke a front axle on my 110, pulled the inner and the CV and stub axle, filled the swivel up with 90 weight and stuck the cap on and drove 150 miles home and had no streaks like you have in your picture.
Old March 25th, 2009, 12:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do I need to worry about what has already leaked out?
Old March 25th, 2009, 12:57 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It's an insignificant amount.
Old March 25th, 2009, 01:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Cool thanks!
Old March 25th, 2009, 01:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
I got to respond with Huh!
Axle breather? glue?
Old March 25th, 2009, 01:59 PM
If you wheel it, keep some spares as they come off (or tear) pretty easy
Old March 25th, 2009, 02:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
I will clean it up and just stick it on. If it leaks then the glue method seems good.
Old March 25th, 2009, 06:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
IF you are getting a lot of oil out to the hub, you may need a new inner spindle seal. That is what keeps the gear oil in the housing and out of the bearing and hub area..
Legend in My Own Mind.
Old March 25th, 2009, 06:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
So annoying. how will i know?
Old March 25th, 2009, 07:22 PM
If it still leaks. I should add that I would check to see if the splines on the drive member (the thing with the axle shaft in the middle of it held on by five bolts) are worn. Mine are ok on both salisburys [ies?] but it is a known issue. Oil could make it out there too.
Ron
Old March 25th, 2009, 07:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
ok after cap is on will give it a few days
Old March 25th, 2009, 07:36 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
I am having the same issue today with my 110. I am told that in 1998 they upgraded the requirements in the manuals for these and instead of 90 weight, now say the acceptable replacement is something that is thicker in consistency called One Shot. I am told the dealership stocks it and it is about $17 bucks a sleeve and it takes one for each of the front wheel hubs. Supposedly you drain the 90 and replace with this stuff, and will never have a leak issue again.
Anyone care to chime in about this, as I am taking mine tomorrow to have it done.
Thoughts?
Dendy
Old March 25th, 2009, 07:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sounds like the swivel housing issue.
Old March 25th, 2009, 07:46 PM
NashvilleRover
Dendy Jarrett
No, mine has oil coming out behind the rubber cap. If enough pressure builds behind the cap, it pops off slightly and 90 weight goes everywhere, until the cap is empty.
Only happens in the right conditions though (as in not all the time), that is why Kelly Graham (Best4X4 on the boards) says to go with the One Shot.
Just sayin'
Dendy
Old March 25th, 2009, 07:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
the one shot fix sounds good to me.
Old March 25th, 2009, 11:10 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, some time ago LR switched to the One Shot Grease tubes. They are expensive, but they sure make the job easy. I rebuilt the swivel balls, installing all new bearings and seals a few weeks ago and used it. Once it is drained you just open up the filler plug, cut the end off the tube, insert it into the fill hole and squeeze it all in there. You need one tube for each swivel ball. Here is a picture of what they look like.
Old March 26th, 2009, 09:54 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks I did the the swivel balls about a month ago. I got the tubes from EE. I am a bit confused though about where the one shot goes in this case. I am leaking out the center of a back wheel.
Old March 26th, 2009, 09:56 AM
One Shot is front only.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
