hub face to hub face axle length - Defender Source
Old June 2nd, 2011, 10:56 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I believe it is 61 inches, but can't remember for sure. Does anyone know??
a 94 defender 90 axle.
Trying to order a custom axle for a trailer and need this dimension.
That is why it is called a short cut. If it was easy it would just be "the way."
Old June 3rd, 2011, 09:00 AM
d110pickup
Mike Pado
'97 D90 ST #1153
You are correct, it's 61".
I just built an axle for my pop-up tent trailer using the ends off a 90 rear axle and the stock stub axles, hubs etc.
ac, axle
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Anyone do this? Bowtracer Defender Technical Discussions 13 March 18th, 2005 02:32 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
