Hub / Center BORE SIZE for Defender Wheels! - Defender Source
Old December 18th, 2014, 02:53 PM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Unhappy Hub / Center BORE SIZE for Defender Wheels!
I am having custom 18" wheels drilled.
I researched online and came up with FIVE DIFFERENT SIZES of the HUB BORE for late 1990's Defender 90! I know it's a 5 on 6.5 (165.1) and nut 16mmx1.5; but What is the real bore size?
This is what I found:
5.15 (130.81), 106.2, 124, 114.3, 113.
Thanks guys!
PS, my first post!
Old December 20th, 2014, 05:59 PM
Rhyno's Avatar
Rhyno
Ryan
1997 JDM D90
I can't help you with those sizes but I'm interested in the wheels your getting made! I should be picking up my D90 on Wednesday in Vancouver and driving it to Kelowna.
Old December 20th, 2014, 06:20 PM
Chris B
72 + D1 drivetrain =?
Wheel stud spacing is the 5x6.5. Now are you asking the size of the hole on the center of the wheel to allow the axle hub space?
Old December 20th, 2014, 06:30 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The wheels need to be hub centric, measure the inside diameter of your existing wheel and use the one closest... a lot of after market wheels aren't machined to be hub centric, that's why the large range of numbers...
If your up my way... call by...
Old December 28th, 2014, 07:48 PM
WestCoastRover
Jeff
2000 TD5
Thanks guys. And yes I was looking for the stock size of the center hole in the wheel.
I ordered them, 5 on 165.1 with a hub bore of 125 (no choice on the hub bore) .... 18x9 with a +20 offset
I will let you know next week when I try them out! And post a picture. Hope they work......
Old December 30th, 2014, 04:01 PM
Rhyno's Avatar
Rhyno
Ryan
1997 JDM D90
I can't wait to see them!!! What company did you get them from and how much? Can you post a pic of the wheel your getting made?
Old December 30th, 2014, 04:20 PM
How big of a tire? That seems a lot of offset for a 9" rim. That would give about 5 1/2" of backspacing.
Old January 5th, 2015, 06:01 PM
Rhyno's Avatar
Rhyno
Ryan
1997 JDM D90
Any updates?
Old January 7th, 2015, 02:16 AM
WestCoastRover
Jeff
2000 TD5
Bolt pattern lined up great as well as the +20 offset on a 18x9 (barely inside the flare). Toyo AT II looks excellent. I will need about a 5mm hub ring (125.1mm hub compared to the 114mm), and I am having an impact socket lathed as the hole does not quite fit the 24mm socket. Boy were lugs hard to find for an M16 stud.
Old November 10th, 2017, 11:12 AM
roadworn's Avatar
roadworn
jonathan
1990 110 5 door
Hi Jeff: iam talking with a wheel manufactuer about custom rims. Could you clarify some things.
What do you mean by "I will need about a 5mm hub ring (125.1mm hub compared to the 114mm)" Where did you find the proper lugs? I assume you did not use any kind of hub adaptor ?
Old November 10th, 2017, 11:52 AM
Naplm00
M
you dont really need the hub ring . LR wheels and hubs and lug centric
Old November 10th, 2017, 12:55 PM
WestCoastRover
Jeff
2000 TD5
On a custom wheel, hub rings gaurauntee the wheel remains centered if there is a gap between the hub and the bore on the wheels center hole. Custom Rings are hard to source/have made and are not mandatory if your stud holes are perfect. The Hub Bore of a Defender is 114.3mm (the center hole in the wheel) Get a wheel with the closest match to that, or have the milling shop make it 114.5mm to 115mm.
CUSTOM DEFENDER WHEEL SPECIFICATIONS:
Bolt Pattern is 5 on 6.5 (165.1) *this is a large pattern and most blank wheels are not designed for this pattern
Two ways to drill the bolt pattern:
A) Drill the holes tight (16mm) so that the studs are what keep the wheel centered (like the classic LR white steel wheels) Use typical M16 tapered lug nuts from an auto supplier. These are often a 24mm Hex (the smaller the hex the better) A 24mm nut means the socket holes need to be 33mm to fit the socket.
Defender hub studs are short (1.5?), so the mounting surface of the wheel should only be 1/2" thick (to allow 1" of thread)
B) Make the stud holes large to exactly accept the Defender alloy style lug nuts. (like the silver NAS alloys) This is a more complicated seated lug system. I do have these measurements if you go this route.
Let me know if you have any more questions, would love to see your wheels!
If you decide to go the adapter route, PM about an affordable adapter that accepts GM 6 bolt wheels.
Old November 10th, 2017, 05:53 PM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, Himalaya110, 97 Hummer H1
Thats great information thank you.
We are having several styles of wheels manufactured for Defender so spacers and adapters will not be necessary.
We are also having heavy plush molded carpet systems for 110 and 90. These will be insulated for sound dampening and thermal protection.
Old November 10th, 2017, 06:19 PM
roadworn's Avatar
roadworn
jonathan
1990 110 5 door
Smile
Thank you Jeff thats all very very helpfull.
Himalaya: we would love to see what wheels you are working on and when will they be available?
Old November 13th, 2017, 05:38 AM
MCMLXIX's Avatar
MCMLXIX
Rich
I would love to see a LR P38 Mondial wheel in a 18x9 with a 5x6.5 PCD...
Kahn makes a 20" version which is a little oversized for most people.
It would be nice to have a high load rating for 110's and 130's that are loaded.
Name:	P38 wheel.jpg
Old November 13th, 2017, 10:41 AM
roadworn's Avatar
roadworn
jonathan
1990 110 5 door
Jeff, can you tell us where you got those wheels?
Old December 12th, 2017, 05:11 AM
MCMLXIX's Avatar
MCMLXIX
Rich
Both these companies have made wheels for the Defender
www.grid-offroad.com
www.adv1wheels.com
defender, wheel, wheels
HELP! Big end bore spec Davis Defender Technical Discussions 10 August 24th, 2015 04:42 PM
Terrafirma Big Bore D90user Defender Technical Discussions 17 July 8th, 2011 07:47 PM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 08:00 AM
front hub nut size? tkavan01 Defender Technical Discussions 11 May 22nd, 2006 05:06 PM
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 04:26 PM
