hub bearing rubber seal - Defender Source
Old September 14th, 2014, 04:37 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
For those who've replaced the hub roller bearing rubber seal, how far is it supposed to sit in the brake disc hub? I've pounded it down with a mallet. Is there supposed to be some wiggle room for the roller bearing assembly, or is the seal supposed to sit squat against the roller bearing? I can't seem to get it in any further.
Old September 14th, 2014, 05:55 PM
grnrvrs's Avatar
grnrvrs
Paul
88
From memory, it should be recessed 4mm. The seal should not be rubbing against the bearing. I use an old drive member to set the hub seals.
Edit: That seal is trashed.
1970 SIIA 88, Sold
Old September 14th, 2014, 08:04 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Should go in all the way I believe which means against the race..... I used old race, flipped it and used it to hammer it in evenly...... seems to have gone back in like a glove
Old September 14th, 2014, 08:11 PM
The bearing sits inside a machined shoulder. When you seat the seal all the way in against this shoulder, it doesn't hit the bearing race at all.
Old September 14th, 2014, 08:20 PM
I just did these. The topmost part of the seal (the part that sticks out and faces the stub axle) must be below the level of the metal lip. 4mm sounds about right. The important part is that it clears the metal lip, otherwise the seal will rub against the face of the stub axle and tear apart in short order, causing leaks.
Old September 14th, 2014, 09:01 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I stand corrected. I don't remember any machined shoulders beyond the center one where both race sit. I hammered it in and went no further.... Looked like where old one sat.
Old September 14th, 2014, 09:56 PM
4mm, I marked it on an old bearing race.
Old September 15th, 2014, 01:45 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
As stated above. There is a tiny lip in there that the seal sits against. Use a bearing race to tap it down.
Old September 15th, 2014, 08:30 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
On my last one, it was stamped right on the seal--how convenient. I believe 4mm was the correct setting. It is in the manual...
Old September 16th, 2014, 02:55 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I think if you have an old hub assembly you can measure the lip on it. It is 4mm from memory. I used those to seat the seals with a rubber mallet.
rubber
Swivel Pin Housing Seal and Bearing Service Manimal Defender Technical Discussions 5 April 23rd, 2014 01:08 PM
Bearing replacement/Hub Seal Darby Defender Technical Discussions 2 January 17th, 2013 05:37 AM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
