How to tell a 2.25 from a 2.5 petrol - Page 2 - Defender Source
Old February 8th, 2011, 02:53 PM
NC Rover
Nick
1971 Series IIa Hybrid
Originally Posted by Ren Ching View Post
NC Rover, does your engine not have a number stamped into the block in the area shown?
Nope...no numbers where you had pictured. See two pictures below...
Old February 8th, 2011, 03:21 PM
Nick
Stupid question but where do you add motor oil to your truck? Since you have the early valve cover with no oil fill, and the later block that deleted the big filler neck.
I wonder if the engine number was ground off at some point. Or maybe it was a replacement casting. I think there are other differences between the 2.25 and 2.5 blocks, something about additional webbing in the casting visible from outside.
Old February 8th, 2011, 07:50 PM
NC Rover
Nick
Nick
I've always added oil straight through the top of the valve cover...just lift up the round black cover (with vaccum to carb) and poured straight in through the opening in the valve cover. Does that answer the question?
2.25 / 2.5 gas engine for 110 kjva Wanted 6 February 3rd, 2011 07:01 PM
2.5 petrol specific question mgreenspan Defender Technical Discussions 3 December 8th, 2009 04:19 PM
series 2.25 petrol 5 bearing CDNRover Series Technical Discussions 8 February 12th, 2009 02:25 PM
2.5 Petrol tomaco1 Defender Technical Discussions 3 August 19th, 2008 11:14 PM
285 75 16's with a 2.5 petrol tomaco1 Defender Technical Discussions 3 January 27th, 2008 11:49 PM
