How to: Replacing brake line? - Defender Source
Old August 8th, 2016, 08:38 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Advice needed:I'm replacing the hard line on the front of my 1997 NAS D90. Anything special I need to know!? She's a little pinched... Thanks in advance for the advice!
Old August 8th, 2016, 09:56 PM
Naplm00
Matthew
Nothing special, just use flare nut wrenches to remove the line. Also might be a good time to bleed the brakes with fresh fluid.
Old August 8th, 2016, 10:23 PM
Make sure you have the correct line before you remove the old one. I thought these were NLA.
Old August 8th, 2016, 10:26 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
If you're replacing the line just cut it and use a socket to remove the flare nuts.
I use a pair of pliers like these for making tight bends.
https://smile.amazon.com/Lisle-44150...ke+line+pliers
Old August 8th, 2016, 10:48 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Atlantic British has them
Old August 9th, 2016, 02:51 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
+1 on this. Definitely cut the line and use a socket to get the nuts off. Will save you a lot of hurt vs rounding the nut with a wrench.
New NAS 90 Fuel Line Hoses (Line to Tank) FS SafariHP The Vendors Loft 0 August 28th, 2015 09:36 PM
1985 ROW D90 clutch slave line? r380 replacing lt77 SkinlessFrank Defender Technical Discussions 5 July 17th, 2013 05:31 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Replacing brake fluid Antonios Defender Technical Discussions 2 September 27th, 2006 09:09 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
» Defender Registry
DD
Howski
Patience
Stormer
Add your Defender
