How to replace a 110 tube - Defender Source
Old February 8th, 2007, 05:27 PM
Red face How to replace a 110 tube
I have the oem michelin tube 750R16s that are tube tires, and I have a flat now as my spare. Strangely enough, I can't seem to find a place here in charlotte that can repair the slow leak on my tube. Every answer is "no we only work on tubeless". I'm ready to do it myself if I can, and my "vehicle expedition prep" manual recommends tubeless anyway due to ease of maintenance in the field, so i should be able to patch the tube, right? until I can spring for new BFG M/T's (which I haven't convinced my wife of as the michelin's have plenty of life left), can anyone provide DIY advice on repair/replacement of the tube? Theoretically, shouldn't be more complicated than a bike tire....
Old February 8th, 2007, 06:54 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Truck stop I would guess.
Old February 8th, 2007, 10:15 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
No point in running tubes unless you know how to fix them yourself. I use a hi-lift to break the bead then a crowbar, 4lb hammer, and a couple of prybars to get one side of the tire off of the rim and the pull out the tube and either patch it or replace it with a new one that I carry for just such times.
Old February 9th, 2007, 09:58 AM
thanks. that's the advice I was looking for. I didn't choose tubes, they chose me when I bought the vehicle. I'll be tubeless hopefully by end of summer.
Old February 9th, 2007, 10:46 AM
Usually tractor places will do tubes. Most of the new tubes are both radial and bias compliant, but call ahead to make sure they have one. 7.50 x 16 is about as common as they get.
BTW I really like tubes as they rarely lose air like tubeless do. I get so many stupid slow leaks if I could find and run tubes in everything I would. Of course they are difficult to patch or replace in the field and generally go completely flat when flat as opposed to a slow leak.
Old February 9th, 2007, 10:59 AM
any thoughts on that green goo that is now sold in stores for bike and car tires as a flat preventative? My leak was a very, very slow leak, so it's probably a pin hole or something.
Old February 9th, 2007, 11:25 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Air it up twice. Once with the valve stem removed and then let it deflate a bit. Replace valve stem and reinflate to correct psi. This helps seat the tube and center the valve fitting in the wheel.
I hate tubes. They always rip when I air down.
JP
legend in my own mind
Old February 9th, 2007, 11:47 AM
Chaucer
Will
93 110 | 97 90
I hear tubes are prone to condensation with temperature/atmospherical changes and this then makes the steel rims rust more than tubless. Don't know how true it is, but it does make some sense.
Old February 26th, 2007, 03:58 PM
For purposes of posterity, I am posting this resource in Australia that supplies tube and tubeless field repair equipment for off roaders, as well as their US distributors. They have an excellent how-to instruction section on field maintenance for tires.
Australian Manufacturer:
http://www.tyrepliers.com.au/home.htm
US Distributor:
http://www.extremeoutback.com/index....d=3217468.2280
110, ac
NAS 110 tube side step landrovered For Sale - Parts 0 July 28th, 2009 09:24 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Best Way to Replace Windscreen Frame Seal on a 110 NAS R. Kurk Defender Technical Discussions 2 July 10th, 2007 08:30 PM
