How to repair aluminum holes? - Defender Source
Old April 28th, 2014, 02:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Can someone with experience welding aluminum tell me how to patch 1/4" - 1/2" holes in aluminum that is approx 1/4" thick? I have a Zodiac Military floor, I mean a Defender part! ...that I want to patch and anodize. What are my options? I found something called Alumweld. Is it any good?
Old April 28th, 2014, 02:31 PM
350rangerover
3
You need a tig welder, take it to your local machine shop and see what they can do.
Old April 28th, 2014, 03:30 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
You should be able to do it with mig via aluminum spool gun and a piece of copper to hold the puddle. At least that's what I'm going to try
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old April 28th, 2014, 03:40 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Can aleays use "aladin" stick. They melt at lower temperature then aluminium and it doesn't stick to steel. Just need to have a plate of steel under the hole and melt the aladin stick to fill the hole. It is a strong product! Won't separate from aluminium and if your not satisfied with the result just use your normal blow torch to melt it back..
Old April 28th, 2014, 04:03 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Using a plate of stainless steel behind the aluminum plate, I can usually run my TIG about 80-100 amps for 1/4" thick filling. I just run circles starting at the edge and going in. Flip it over afterwards and fill any craters, then use an air grinder to flatten it all out. Make sure it looks pretty well blended before having it anodized.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old April 28th, 2014, 04:28 PM
http://www.alvinproducts.com/Products/Products.asp?id=1
Old April 28th, 2014, 10:38 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks guys! I think I'll try the TIG route first. If some wiz can melt some aluminum to fill the hole that would be ideal. If not I'll try the silly putty.
Old April 28th, 2014, 11:35 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
When I have small holes in the skin of aircraft, when they are just too small to bother with a coin patch I use JB Weld. I use some tape with smooth adhesive, like clear thick packing tape. Put that on the side that shows. Mix up the JB weld and place it in the hole, use a toothpick to get al the edges filled in. Then I go about ¼ inch beyond the hole on the inside and cover with a small circular piece of fine glass mat. Put some Saran wrap over it and press the glass mat into the JB weld and smooth it. Let it set, peel the saran wrap off the backside and the tape off the front. Light sanding and they are almost invisible from the outside after painting. You can pant on some one thin JB Weld on the inside to smooth it a bit to get the glass pattern from showing.
If you hole is bigger than a quarter, then a circular coin patch is the best route. After you shave the rivets and do some light fill, they are invisible from the outside.
http://www.wikihow.com/Repair-Minor-...ft-Skin-Damage
Old April 29th, 2014, 12:44 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Another filler solution for small holes is Devcon epoxy. They make a version for aluminum and one for steel...I think they even have one for titanium. It's not as cheap as the JB weld, but it's super durable and easy to work with. Just don't build it up too far and have to sand it much - it's a real bugger to sand once it sets hard!!
Dilling holes in aluminum body panels fenwaystan Defender Technical Discussions 1 March 22nd, 2008 01:14 PM
Sealing Rear Wheel Well Bolt Holes Boone90 Defender Technical Discussions 10 February 18th, 2007 01:30 PM
Where is the best plast to drill holes for recovery points on a Defender front bumper solihul Defender Technical Discussions 5 May 15th, 2006 06:34 PM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
Weep Holes? Eric Siepmann Defender Technical Discussions 6 June 17th, 2004 09:20 PM
