How to remove steering column? - Defender Source
Old October 21st, 2003, 07:42 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Question How to remove steering column?
I am trying to remove the steering column in my 90. I have everything taken apart, and have removed the steering wheel and turn signal/windshield wiper assembly. Now the only thing keeping it from sliding through the bulkhead is the assembly that holds the lock cylinder. It is two pieces, and is clamped onto the column by two bolts/screws, but the head is smooth, so there is no way I can see to get these bolts out. Any help is much appreciated.
Old October 21st, 2003, 08:28 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
you must use a "easy out" and drill out the bolt. not sure if thats the right term but you can pick up a set at Sears ($20-$30) It is easily done just a little awkward.
They are security bolts that when installed the driver heads torque off leaving a smooth bolt head. thus making it harder to steal the truck. I'll look up the replacement part # tonight for you and will post it tomorrow.
hope that helps,
Read
Insert pithy quote here.
Old October 21st, 2003, 08:45 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Thanks Read, I would have never thought of that. I appreciate the part# too, as it takes my local dealer forever to look up part #s, as they rarely deal with D90's. Thanks again.
Old October 21st, 2003, 09:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, I just did this too. Like he said, just easy out the 2 bolts. The part # for the bolt is 51K4001L sheer bolt..
RAndy
Old October 22nd, 2003, 03:48 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
oh well, look's like randy beat me to the part #. you can replace with allen head cap screws instead. It just makes you truck a bit easer to steal. The up side is if you ever loose your keys, you can just hot wire it.
Old October 22nd, 2003, 07:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thats a good Idea. I would go with the allens or even security torx..
Old October 22nd, 2003, 07:24 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
oh... security torx, even better!
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Steering column new or used CDeWan Wanted 2 September 17th, 2008 03:46 PM
Steering adaptor for Euro spec column? KevinNY Defender Technical Discussions 4 November 27th, 2006 05:05 PM
steering column u-joint Noah Defender Technical Discussions 0 September 8th, 2004 07:04 PM
» Defender Registry
Ralph
modrover
Tina
UtahD90
Add your Defender
