How to remove in fender blower box - Defender Source
Old November 9th, 2013, 09:37 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm trying to clean up the under hood area in preparation for my AC condenser and I realize this huge chunk of plastic in the fender needs to come out. Do I need to pull the fender to do this. I took a cursory look and I don't think its coming out trough the engine compartment.
Any advice would be appreciated.
Oscar
Old November 9th, 2013, 10:04 PM
Oscar
I'm assuming you mean the plastic blower "reservoir" (for lack of a better term) and not the heater blower itself.
No need to pull the fender. I've done this before, and literally just did it yesterday. Just unbolt the bracket that holds the coolant reservoir (take reservoir out first), then do the same for the wiper fluid reservoir and bracket. Wingtop vent take that off too, and there are 2 screws under the vent that holds that plastic heater intake in place.
You'll need to flex the fender up slightly and push the plastic heater thingy down/flat and you should be able to get the small side towards the front of the truck out and then the whole thing slides out.
Old November 9th, 2013, 11:36 PM
michael67's Avatar
michael67
Michael White
110 Tdi
If you use Jason's method, if it's old it may split like mine did. They're fairly inexpensive, and duct tape will also work for repair.
Old November 10th, 2013, 12:57 AM
BlackField's Avatar
BlackField
Oscar
D110
Thanks for the advice Jason I'll give it a go tomorrow. Michael, Its not going back in so the more pieces it breaks into the better!
Old November 10th, 2013, 10:13 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
If this is a LHD intake and you get it out with out damaging it i would be interested in buying from you. Send a PM if your are willing with a price.
Ryan
Ryan
84 110SW County LHD
07 L322 Vogue
Old November 10th, 2013, 10:44 AM
BlackField's Avatar
BlackField
Oscar
D110
Ok Ryan I'll try and get it out in one piece.
Old November 10th, 2013, 06:56 PM
BlackField's Avatar
BlackField
Oscar
D110
If it wasn't for the prior owner welding a few brackets it would have come out much easier. Came out in two pieces the blower and the "reservoir thing".
Ryan, sent you a PM.
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
RHD Blower motor or Heater box Jymmiejamz Wanted 2 February 9th, 2012 10:23 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
NEW IN BOX D90 right front fender d90guyinla For Sale - Parts 5 October 3rd, 2006 01:05 PM
Waterproofing speaker box? Helihntr Defender Technical Discussions 9 May 26th, 2005 12:31 PM
