How to remove driver door lock cylinder??? - Defender Source
Old February 6th, 2016, 03:01 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
I am trying to remove the cylinder out of my lock on my '97 ST. I have a new lock without cylinder. I have searched here and googled and cannot find any helpful information on how to remove the key barrel from the lock. I have tried sticking a pin into a small hole on the cylinder housing with key inserted, this did not work. The page in the workshop manual is equally unhelpful. What is the trick here?
ID:	141696   Click image for larger version
ID:	141698   Click image for larger version
Name:	Door Lock Removal Manual.png
Old February 6th, 2016, 03:24 PM
IIRC there should be a hole that you can put a pick into to unlock a small detente. This should allow you to insert the old key and remove the lock cylinder.
Old February 8th, 2016, 12:53 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
i had a similar problem. I was able to get the passenger side out easily but the drivers side was stuck. You put a small pick/nail whatever in the hole and as I recall turn the key a little to pull it out. You may have to spray some lube in there as it is likely gummed up.
door
Driver door lock Rhyno Wanted 4 February 27th, 2015 02:09 PM
Lock Cylinder removal bjf Defender Technical Discussions 9 July 28th, 2010 07:49 PM
what is the best way to remove the hardware on a door to change out the door cards grbec22 Defender Technical Discussions 2 July 28th, 2010 11:21 AM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
How do I remove a lock cylinder if I don't have the key? evilfij Defender Technical Discussions 5 May 1st, 2009 01:45 PM
