How to remove dash part - Defender Source
Old May 12th, 2010, 11:02 PM
bd90
94 Arles Blue #1644
The gray plastic piece inside the dash that covers the air vents. Is there a trick? Have removed the two top screws and the two gray plastic push rivet type things that I thought were holding it on but it won't budge. Trying to replace the windshield washer jet and tubing.
Old January 2nd, 2012, 08:19 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Bump. Same problem
Old January 2nd, 2012, 08:34 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I did this recently and its a pain. I may have done it the hard way though. There are indeed two large push pins as well as several smaller ones along the bottom where it meets the "tray". Mine also had two little screws somewhat hidden along the top edge. I pulled the top of the dash off and also removed the plastic coping that runs along the edge of the lower part of the dash. I then then just carefully wrestled it out. Keeping the vent controls in the closed position was easiest. I had to flex it a bit to get it out.
Old January 3rd, 2012, 12:35 PM
On my RHD truck, I had to remove the lower airbox and top crash pad to remove the grey plastic thing.
Old January 3rd, 2012, 03:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
me too, but I had my wife use her tiny hands to actually replace the washer jet, there isn't a whole lot of clearance even with that part of the dash removed.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
dash, part
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
dash console - Part# and where to get one? rlynch356 Defender Technical Discussions 2 February 17th, 2010 08:03 AM
Misc. Dash Part Reese_D90 Wanted 8 January 18th, 2010 06:41 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
