how to reduce the tire diameter 4 inches? - Defender Source
Old February 16th, 2010, 10:54 AM
cdb
Clark Bowen
I have 35" tires (really 34" on the tape) but I'd like to squeeze the spare down to about 30" for in-rig mounting.
I reduced the air to 10 lbs but that wasn't enough.
I though about reducing it further and ratchet strapping it like you do when you try to set a bead. Since I carry an air tank I'm not worried about resetting a bead or airing back up but I'm not sure if I can compress the diameter this much and if it would be, long-term, harmful to the tire.
Any other solutions or thoughts?
2011 RR HSE -
2001 GMC 2500 4wd
Old February 16th, 2010, 11:02 AM
How are you planning on mounting it? In other words can just two sides be compressed?
Old February 16th, 2010, 11:33 AM
What about pumping/vacuuming the air out of the tire? This should collapse the tire down, while still keeping the bead.
Old February 16th, 2010, 11:34 AM
cdb
Clark Bowen
I'll rachet strap it to the floor for now. 2 straps in an "x" pattern
2011 RR HSE -
2001 GMC 2500 4wd
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
Educate me on Tires for my 90 coryhula Defender Technical Discussions 6 August 16th, 2006 12:05 AM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
