how to put a tuffy box in my 95 d90 - Defender Source
Old April 13th, 2007, 06:34 PM
steve mez
Steve Mez
1995 NAS D90
guys i need some help on how to put in the tuffy console box in my d90, i just took out the cubby box
thanks guys
steve
Old April 13th, 2007, 07:05 PM
Andrew Vick
Andrew Vick
95 D90
I just pulled mine out to have it refinished. It's secured in the back 2 corners with 2 bolts that go through the floor. The front is attached to the raised bracket support in the same fashion. I should have it back from Tuffy early next week and can take pictures.
Old April 14th, 2007, 12:27 AM
JakeW
Walt
2015 range rover evoque
Registered User
My tuffy's got two bolts in the rear corners and one in the center of the front. All three go straight through the body and are secured with a washer and nylock nut. Don't know if that's how you want to do yours or even if that's how they come from tuffy. Previous owner installed/had it installed. If you're interested I can take some pics.
Old April 14th, 2007, 11:46 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I got two pieces of square tubing to raise the box above the riser in the front and the lip in the back where the tub and seat box connect. I drilled holes through the square tubing and bottom of the tuffy box to line up with the threaded holes where the old cubby box attached. I reused the bolts from the original cubby and bolted it down. This setup makes things easier as I don't have to try and hold the top of the bolt as I tighten the nut underneath the car. The new Tuffy is attached with 4 bolts. I painted the tubing black to match. I can try and take some pictures if you like.
Old April 14th, 2007, 12:24 PM
JakeW
Walt
Registered User
Steve,
Raider's install sounds a lot better than mine. See if you can do it his way. No holes all the way through and reversible. Its true, getting under the truck and having a buddy hold the top of the bolt sucks, and vise grips seem to come off more than they should.
Old April 27th, 2007, 04:03 PM
steve mez
Steve Mez
1995 NAS D90
so to installing the box you need to drill? can some one try and tell how to do this in steps.
thanks
steve
Old April 27th, 2007, 04:27 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Raider, I would like to see some pics. I am getting ready to do this upgrade.
thanks!
bil
Bill
Old April 27th, 2007, 04:44 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I think this is the idea
I tried this last weekend, works like a charm.
I attached the aluminum tubes to the floor with the original hardware. Then I used self tapping sheet metal screws to attach the console to the tubes. I only had to drill one hole (the front one) in the Tuffy Console.
Old April 27th, 2007, 05:04 PM
Andrew Vick
Andrew Vick
95 D90
I don't think a 35 pound box secured with sheet metal screws is particularly safe. Bolt it through the braces and through the floor.
Old April 27th, 2007, 10:58 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I'll try and take a picture tomorrow, but I am out of town for a while and all I have is the camera on my cell phone. Here is a drawing that probably explains it the best. I'll try and answer any questions to clear things up. I hope this helps.
Name:	Tuffy Install.jpg
Old May 1st, 2007, 12:50 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I went to try and take some pictures, and couldn't get a shot that showed any more detail than the drawing does. If you would like a shot on how things look when all is said and done, let me know.
Old May 4th, 2007, 01:19 AM
steve mez
Steve Mez
1995 NAS D90
that would help me out, i think tuffy sent me the wrong hardware and the screws do line up
Old May 4th, 2007, 08:21 AM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I'll take some pics this afternoon. I don't think I used any of the Tuffy hardware. I reused the 4 bolts that came out of the original. I am pretty sure that I had to dril 4 new holes in the bottom of the Tuffy cubby box that lined up with the threaded holes in the floor.
Old May 4th, 2007, 08:36 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine came with 2 small hollow spacers to go between the box and the floor to keep it the same hight as the ridge front and back. bolt up from underside with a nut on the lower part of the spacer, one bolt through the cover plate at the front, slide box over the bolts and use wing nuts inside. no need to go underneath to take box out again, two min job to take out
i can understand what i'm on about will take a picture tomorrow
3rd low and BOOT IT
Old May 4th, 2007, 01:22 PM
kolvedic's Avatar
kolvedic
Bill Lewis
awesome idea! I was thinking I could just get some hollow material and cut my own spacers.
bill
Bill
90, 95, d90
95 D90 Sw TwisteD90 For Sale - Vehicles 5 November 20th, 2008 11:10 AM
Rear Tuffy Box for a 110 pcarey Defender Technical Discussions 12 March 4th, 2006 11:27 PM
95 D90! TwisteD90 For Sale - Vehicles 30 September 14th, 2005 02:54 AM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
Diagnostic Plug on 95 D90 SW? Troys Defender Technical Discussions 5 March 13th, 2004 03:49 PM
