How To install Badger Gutter Kit ??? Help - Defender Source
Old November 5th, 2005, 09:38 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Can someone email me the installation instructions on the gutter rail kit for a badger top? Pics... Where to cut the header bar? How the pile of shi% goes together?
We want to install it on Jorges truck but don't know how...
Legend in My Own Mind.
Old November 5th, 2005, 09:55 AM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Randy,
Did it not come with some instru? I install mine yesterday. I still have the instruction that I can send over to u.
David
Old November 5th, 2005, 10:45 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thnaks for the pics. Is there 2 different ways to install the gutter kit though? The one we have here looks like it uses the original vertical and horizontal pieces that go around the door some how.. unlike the new ones that have a new style vertical piece that goes behind the door and into the the slot on the roll cage.
Old November 5th, 2005, 12:31 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
Randy,
Jorge should order the newer style upright brackets from us. The horizontal bars that are with that kit date back to 1998, which is also how old the top is. If Jorge wants to use those, just spin it around so the bolt on the front edge bolts through from the inside of the winshield frame. The nut will be on the outside of the upper drain channel on the front edge..
Sew on and sew forth...
Old November 5th, 2005, 05:41 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thanks for the info Chris. I will pass it on. I thought they looked different to the newer ones that I have seen from you guys. The newer ones look alot easier.
badger, kit
Badger Gutter kit install weissbrewer Defender Technical Discussions 5 November 25th, 2006 01:20 PM
seeking Badger gutter install instructions Gkase Defender Technical Discussions 3 February 26th, 2006 12:28 PM
Badger Soft Top with gutter kit Tom B For Sale - Parts 2 December 16th, 2005 05:35 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Badger Gutter Rail Kit TDI Guy Defender Technical Discussions 3 March 24th, 2004 09:55 PM
