How to identify TDI engines? - Defender Source
Old February 13th, 2011, 06:50 PM
okyrover's Avatar
okyrover
Timothy Chesnut
1995 NSA Defender 90 SW
How can you tell between the different TDI engines which is which? Were can I find info on the land rover TDI engines? Looking for info like years made, modes, power, and how they work.
Old February 13th, 2011, 07:04 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
The easiest way to tell the difference between the 200 Tdi and 300 Tdi is to look at the belts. 300 Tdis are serpentine.
Wikipedia has a lot of info, just search "land rover engines".
You can also go to http://www.landroverexpedition.com/engines/ for info as well.
Old February 13th, 2011, 08:16 PM
The safest way is the water outlet elbow/thermostat housing. I have seen disco 200's fitted with serp belts. Global had one for sale @ one point. 200's were made from 89-92.
There is a wealth of information on this out there and google will probably be your best bet. There are very few differences and a lot of what you will read will be personal preferences based on someone owning a strong runner that went forever. The heads are slightly different castings but the manifolds etc are interchangable. The blocks are both 2.49 liters and again pretty much the same. The 200's had two different configurations the disco and defender versions these used different front covers, ancillary's, and manifolds and turbos, again this stuff can be swapped back and forth. The 300 engines had no differences between the disco and the defender except that very late disco 300's had a "fly by wire" system that made slightly more power for trucks with automatics. These can be retro fitted with mechanical injection pumps but there are so many of the mechanical's out there that makes little sense. The 300 is the later design although only by four years. A/C retro install kits are still available for the 300.
Many swear the 200 gets better mileage.
I have too heavy a foot to weigh in either way.
Old February 13th, 2011, 09:01 PM
okyrover's Avatar
okyrover
Timothy Chesnut
Thanks for the info
engine, tdi
Fuel additives for tdi engines? Hoosier Defender Technical Discussions 27 December 7th, 2009 11:18 PM
tdi engines rovernutzz For Sale - Parts 6 June 22nd, 2008 03:00 AM
