How to get this Black Goop Off? - Defender Source
Old June 22nd, 2015, 08:36 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Okay, so I pulled the cardboard trim around the clutch\brake\acc pedals this weekend..
And the foam strip that was glued to the top edge has deteriorated into a black, sticky mess. I've tried Goo Gone, Goof Off and other cleaners, but this stuff won't let go...
I have a few bolts that are covered in it soaking in Gasoline right now, sort of a last idea..
Anyone else find anything that works to get this stuff off?
P.S. - Changing the Clutch master. Never thought I was going to gt that damn pedal box out of the hole, but it did eventually come out, as all the threads say. Now I just have to do the flex line, Slave and bleed the system. Oh yeah, and figure out how to get the hood back on.. LOL!
~Scott T.
'95 D-90 ST - AA Yellow
Old June 22nd, 2015, 09:12 AM
Diesel or mineral spirits.
Old June 22nd, 2015, 11:28 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Xylene
Old June 22nd, 2015, 11:32 AM
BlackField's Avatar
BlackField
Oscar
D110
I keep a can of Xylene around also.
Back in the day I used to use Trichlorotrifluoroethane on everything. It was like magic, spray it on your messy spot and everything evaporated into the heavens, magic.
Old June 23rd, 2015, 02:57 PM
Naplm00
Matthew
Brake cleaner on a rag
Old June 23rd, 2015, 04:06 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Aceton!
When turning the clutchpedal 90 it's sometimes necessary to make a short slot into the opening. Just as wide as the pedal's (rubber is off) thickness.
Old June 23rd, 2015, 04:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Arlo View Post
Aceton! When turning the clutchpedal 90 it's sometimes necessary to make a short slot into the opening. Just as wide as the pedal's (rubber is off) thickness.
Arlo - do you use Acetone for a metal prep before you weld? I have been using it for the past month or so. I use it after sanding with a flap disk and it seems to help out.
Old June 23rd, 2015, 05:09 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I just use a flap disk to keep the surfaces metallic clean before welding.
Only when trying to solder parts I use acetone or cellulose thinner to get the surfaces free of fat.
ac
How do these get into the USA and get sold? Grover Misc. Chit-Chat 33 April 23rd, 2012 01:15 PM
Black 'Goop' under clutch/brake pedal Boxes? LRNAD90 Defender Technical Discussions 6 April 26th, 2009 11:29 PM
How do you get the adhesive residue off (JimC?) evilfij Defender Technical Discussions 8 April 13th, 2009 12:37 AM
what's this goop called? Gkase Defender Technical Discussions 7 October 31st, 2006 10:17 AM
I'm trying to get the automatic gear shift handle off and I need some help KeithElisa Defender Technical Discussions 4 November 30th, 2004 12:01 PM
