hi guys i need help
i have defender 90 model 1985 v8 3.9
the rear axle is drum brake i bought the svx wheels from johncradock
so how can i instal them do i have to change the rear axle
or if there is something i can do plztill me
Ok is it possible to change only the drum and replace it with disc
Or i have to change the rear axle
And for the spacers how many millemeter it should be there is some places i can order
Because there is places in my country making them
thnx guys i will talk to my mechanic
ifound some spacers but the shipping price is higher than there original price
i can change the axle for
320 or 350 usd with installing
i found the spacer online 140 usd the shipping 175 usd total 315
thnx alot will do that
i am making my defender like the fire edition the only problem i have got is fixing the svx on them
but thnx to u guys i have the answer
I am soon to have the same problem!!! I was told by a couple of people that 1-1/4" spacers would fix the issue. Where did you find the discovery axles? Can you change out the enitire rear end?
Yes u change the rear axle my mechanic tolled me some parts need welding
But for me i will change the rear axle its cheaper than buying the spacers cause shipping the spacer to my country is costing me more thn there original price
I will post a picture as soon as the car be ready its in the garage for painting
All of the extrior will be replaced with original svx grille original svx side steps original svx headlight svx rear lights
All of this items are original not like the kbx grille no original svx grille
I will post some pics as soon as the car ready scoot
Welding ? Shouldn't need any. The disco axle is a direct bolt in replacement, you pick up the 24 spline axle shafts and rear disc brakes-nice upgrade and only takes a couple of hours. The local pick and pull yard here sells them for $100.
I found an complete rearend today from a dicso 1. Will it bolt in or do I have to weldup any parts. Or can i just swap out the axels and reuse my current housing? Which is the best in the long run? I have a 1992 Tdi defender.
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
