HOW TO: Dorman Clutch Master Cylinder Conversion (Defender & Series late-IIA & III) - Page 2 - Defender Source
Join the Defender Source Community Today
Old January 21st, 2016, 08:56 PM
The 2002 workshop manual was last updated in 2011...
------ Follow up post added January 21st, 2016 09:00 PM ------
I would recommend using DOT 3 if you are the sort of person that would use metal head gaskets instead of composite head gaskets on your V8.
Old January 21st, 2016, 09:34 PM
DOT3, DOT 4...DOT221...whatever it takes .
Well, with the Dorman now I've been running dirty dishwater and it's functioning just fine. I may upgrade to dog saliva soon to see how it compares.
All joking aside, like Jeff said it's ridiculous if Rover hydraulics are that finicky...and was one more reason for the swap(s) on my end. I'd love to run something like DOT5 that's silicone based and won't strip away the paint if you spill one damn drop by accident when you're filling things up.
Old January 21st, 2016, 09:38 PM
I mean water will work too if you don't get the brakes too hot
Old January 21st, 2016, 09:52 PM
The hydraulics are designed and supplied by Lockheed and use the same design and components as every other braking system on every other car. They are just as compatible with regular brake fluids as everything else. There is nothing special being used in a Defender.
Old January 21st, 2016, 11:03 PM
Okay. 25 years with all original brake hydraulics and no leaks. How long are they supposed to last? Change the fluid every two years like you should do on every car.
Old January 21st, 2016, 11:20 PM
I see parts come through for a lot of people. I rarely see hydraulics. I really don't believe failures are any higher than any other car if you remove crappy aftermarket parts and poor maintenance from the equation.
Old January 22nd, 2016, 07:01 AM
From what I understand about the low viscosity fluid is that it offers better low temperature pedal feel. Most European cars now call for LV fluid.
Old January 22nd, 2016, 07:11 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Agreed !
Nathan very nice upgrade Thank you for taking the time to put it together
No Mall crawler here
Old August 27th, 2016, 08:34 AM
speedpin's Avatar
speedpin
Ordered the SDO dorman Kit on Tuesday. Jason was out of town but had it to me by Friday, I was taking the 110 to Lexington Va Today! Kit was complete drop in. I had a dripping clutch pedal and leaking oem master cylinder.
Followed the steps above for my RHD 110. Took about 2 hours. Adjusted and took for a test drive. Great feel and dry as a bone again.
Thanks Lav "SDO"
ID:	156515   Click image for larger version
ID:	156517   Click image for larger version
ID:	156519   Click image for larger version
~ Semper Fidelis ~
Old September 25th, 2016, 03:27 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Jason, do you sell the hose by itself?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 26th, 2016, 04:20 PM
Mike & Carrie
Sent you a pm....glad to help out.
Old November 19th, 2016, 10:28 AM
ugly90
1987 90 ExMod FFR
Good writeup on the master cylinder change. I find they don't last too long, but mine are always decades old. I usually find the seals to fail, rather than aluminum. Having the unit sitting for years, water in the brake fluid, or using synthetic fluid can damage the seals. It has been very difficult to find a non-synthetic DOT3 or DOT4 fluid. The big box autoparts stores didn't have it, I had to find a parts distributor that shops use. I found bottles of " Kleen Flo " DOT3 that expressly were not synthetic.
Old November 19th, 2016, 12:40 PM
Yeah I was lucky to get 10k miles out of a MC....but admittedly the off-road use probably amplified my issues - though many, many others saw/see similar problems with Rover hydraulics so I know I wasn't alone .
The other nice thing about the change....as you alluded to, there is no more need to be overly finicky or try to run "special" fluids with the Dorman. While I'm still running the Castrol GT LMA, the reality is any DOT 3/4 would be fine. Many - including myself - found it absolutely annoying to source some particular fluids for the clutch hydraulics. I mean, it's an old Land Rover....not a Maclaren.
Old November 21st, 2016, 09:36 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Further kudos to Jason. I just installed my SDO Dorman kit yesterday. Awesome directions, top notch quality. The braided line is a massive upgrade, and the directions were invaluable (especially for us LHD folks, for which this job is a total PITA). I wouldn't have necessarily had the courage to just unmount the brake booster, but thanks to his directions, it was all "paint by numbers." Clutch is good to go now.
Special bonus for meeting me to pass it off on a Saturday so I could do the work at the father-in-law's fully equipped garage on Sunday.
And to my LHD drive brethren, get yourself a set of these and a nice long extension before taking on this job:
It makes getting at a bunch of the parts infinitely easier.
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old November 22nd, 2016, 10:17 AM
Dan - glad it worked out for you, I figured my ridiculously over-detailed install instructions would either scare you off or be just what you needed...glad it was the latter . Always happy to assist anytime of day or night for a fellow Rover owner (and local guy!).
defender, clutch, master, conversion, series
Master cylinder & clutch reservoir ome or aftermarket Vieques Rovers Wanted 0 April 11th, 2015 08:45 AM
FS: Clutch Pedal & Master Cylinder spartan For Sale - Parts 6 June 17th, 2014 09:45 AM
Late Series IIa or Series III wings fenders aka rover Wanted 7 May 11th, 2014 11:44 PM
Clutch Slave & Master Cylinder kzack Wanted 3 January 29th, 2014 12:38 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
