How to Disassemble Door Latch for Install - Defender Source
Old October 10th, 2015, 01:32 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Hey folks, I feel real dumb here, but I can't for the life of my figure this out.
I've got a new rear door latch that I'm going to install on a new tailgate that I'm converting to swingaway.
Surely there is some way to detach the outer handle so that I only have to drill holes in the tailgate the width of the two barrels, right? It doesn't look like there's a c-clamp in there, the tolerances are too tight. My other thought is it's pressure fitted. I have a puller (technically for plumbers) but is that the solution for pulling the handle off, then carefully hammering back on after install?
Otherwise my options are to A) drill a big enough hole to sort of snake the handle through but then it's unnecessarily massive or B) drill out the rivets/welds on the whole unit, take it apart, then reassemble it with nuts and bolts.
Another angle for fun:
I just know there must be an easy solution for this that i'm missing that would account for why it's too obvious for there to be tutorials anywhere online!
Old October 10th, 2015, 01:47 PM
On a normal door, there is a big hole that the latch handle goes through and sits inside a recessed area. The lock goes through its own hole.
Old October 10th, 2015, 01:49 PM
Old October 10th, 2015, 01:57 PM
Big enough hole.
Def 90 tail gate ? - Defender Forum - LR4x4 - The Land Rover Forum
Using original tailgate latches.
https://www.boab.biz/mantec.html
Old October 10th, 2015, 04:27 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
That link shows it's possible to take the handle off. The hole is just for the barrel. I need to figure out how to get the handle off to do that very setup (plus 2nd hole for lock barrel).
Old October 10th, 2015, 05:03 PM
Umm. Nope. That latch has no lock barrel. They made the hole large enough to get the handle through.
Old October 11th, 2015, 06:53 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
I know this one has no lock, but that doesn't really change the install process. And I'm still not convinced that hole is large enough to snake the handle through. The handle gets deceivingly wide at its peak.
New question, do y'all think I'd just break it if I tried to use the puller to pop it off?
door, door latch
How does one disassemble an older style dash? IPSC_GUY Defender Technical Discussions 6 January 17th, 2010 10:13 PM
Passenger Door Disassemble JohnsD90 Defender Technical Discussions 2 March 7th, 2009 07:55 PM
Door Latch/Top Adjustments AggieD90 Defender Technical Discussions 6 November 19th, 2008 03:55 PM
SW rear door latch mechanism roverboy For Sale - Parts 8 March 22nd, 2007 02:42 PM
Door Latch Removal outfield Defender Technical Discussions 4 July 24th, 2006 11:49 PM
