The process of converting a 1994 NAS D90 from the square rear lights to the newer style 95 & 97 lights.
The parts you will need ahead of time:
New wiring plugs needed (Female)
2 Way Econoseal Plug Assembly (Female) x 3
3 Way Econoseal Plug Assembly (Female) x 2
You can buy from any source, but here is one:
AutoSparks
http://www.autosparks.co.uk/index.php?cPath=94&page=4
If you have not already done so, remove your existing lights and we can begin.
Let’s start with the easy part:
Use the attachments provided for Templates on placement of new holes needed, a simple hole-saw is more than enough for this.
Tape surrounding area off were holes will be drilled, you can use a plinth to help center the hole saw while drilling if you don’t have a steady hand.
You can move to the fun part now, the wiring:
Starting from the driver’s side moving from left to right, Stop/Tail light
(Looking down from back of connector with TAB facing up)
RED/Black Stripe Black Green/Purple Stripe
Turn Signal (Drivers Side)
Black Green/Red Stripe
Backup Light
Black Green/Brown Stripe
Passenger Side Stop/Tail Light
Red/Orange Stripe Black Green/Purple Stripe
Passenger Side Turn Signal
Black Green/White Stripe
AutoSparks
Backup Light
