How to check fuel pressure? - Defender Source
Old January 10th, 2005, 03:26 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
My right bank is running much hotter than the left, way too lean...
Could this be a lack of fuel pressure? What is a good tool, method to check the pressure.
My idle is also not dropping below 950 rpms.
It is also not starting well when it is cold (2 mins when below freezing). Warm starts almost perfect.
1995 D-90
4.6 with RPI's chip
Everything stock except for air filter....
Still having the same problems from my last post.
I have had so little time to work on this truck, I do not want to keep neglecting it.
Thanks in advance,
Heath
Old January 10th, 2005, 04:23 PM
I wouldn't think that it is the fuel pressure problem unless the fuel rail is clogged 1/2 way (this has happened before). Maybe the right side O2 sensor is bad and causing that side to run lean? You could switch the sensors from side to side to see if the problem fallows the sensor. How do you know that the right side is running hotter then the left? Maybe the cat on the left is clogged causing the problem?
Old January 11th, 2005, 01:47 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
The bright red cat section let me know it was a little too hot...
On second thought what could also be keeping the idle so high, (around 1000 rpms).
And after you hit the accelerator it will not drop below 1250 rpms unless you fiddle with the linkage.
Even when the linkage is forced closed all the way, it will never drop bellow 900 rpms).
Also code 14 will not go away. I replaced the sensor and still nothing. Maybe I frayed a wire somewhere.
When I disconnect the O2 sensor I get no other code...
I disconnected the MAF sensort just to check and that does give me a code... 12 I think...
I thought there might be a vacuum leak so I checked around with some propane and nothing seems to be leaking. (besides the computer would compensate for a small leak anyway ((I think))).
So my problems are high idle, and running too lean especially on the RH side (passenger)
Any specific procedures I should try?
The exhaust is NRP front to back.
Thanks again!!!
Old January 11th, 2005, 02:28 PM
If you haven't reset the ECU, (sometimes after a couple resets things fix themselves . If the CAT is red then I would guess the O2 reading would be a bit off, thus the ECU throwing the code. Pull the O2 sensor out, I think the engine runs rich when the sensor is either disconnected or pulled out. I would also pull and clean the IAC stepper if you idle is erratic.
fuel
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
Testing Fuel Pressure Doug Defender Technical Discussions 4 December 14th, 2003 02:59 AM
