How to bypass Hazard Switch (to keep your turn signals) - Defender Source
Old December 24th, 2013, 05:05 PM
Recently had to pull my NAS hazard switch, and I know many in the past have experienced issues with this switch itself (it seems to be a common failure point these days).
Anyhow, I figured out how to "jump" the switch once it's removed so you can retain your left & right turn signal functions using the indicator lever/stalk on the steering column. Essentially, what you have to do is jump the 2 bottom female terminals (as seen in the 2nd photo) on the hazard wiring harness...and voila, you have turn signals again!
This was plaguing me while I worked on my switch as I don't like to drive without turn signals, so grabbed the multimeter and set to work.
Hope this helps someone else as well...
Name:	IMG_4269 - Copy.jpg
ID:	86653   Click image for larger version
Old November 13th, 2016, 08:32 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
My hazards and my turn signals don't work, symptoms just like Jason described. I tried his jumper, but it didn't work. All the fuses in the box behind the shifter are fine.
Any other ideas that you guys can suggest?
Old November 13th, 2016, 08:56 AM
BlackField's Avatar
BlackField
Oscar
D110
Did you check the turn signal stalk/switch?
Old November 13th, 2016, 09:27 AM
Flasher relay would be my starting point. Relays are switches and the contact points burn.
Once had an issue where nothing worked on my 110 and the flasher relay was full of water, small price to pay for being able to drive through 5 feet of flowing water.
Old November 13th, 2016, 10:38 AM
loykd's Avatar
loykd
Ken Loy
Where's the Flasher Relay?
I'm doubtful that it's the turn signal stalk.
Old November 13th, 2016, 01:48 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Mine (1984) is behind the fuses, inside the panel in front of the shifter. I think in newer models, which use more relays, they put some relays behind the instrument panel (in front of driver).
Old November 13th, 2016, 05:35 PM
Sandy Landy's Avatar
Sandy Landy
RCer
97 Defender 110 300TDI S
Signal flasher on my 97 110 300tdi 3door is behind the instrument panel....i just came upstairs, could have taken a pic for you, can still do tomorrow.
It might be the flashing unit indeed, but check fuse too, if blown..check for short before replacing.
My 89 CSW 200tdi had it within the fuse/relay compartment.... yours might be behind the instrument cluster, I will be relocating mine for easy access.
Old November 13th, 2016, 10:54 PM
carlosz's Avatar
carlosz
Carlos
Jason, fyi if you present the vehicle for state inspection in va and if the inspector is doing his job not just licking and sticking, you will fail state if hazards do not work.
not bursting your bubble, just a heads up...
the truck ran like a "raped ape"
A fussy warm weather creature...
Old November 14th, 2016, 04:03 AM
Not bursting my bubble, this original thread was meant to be a "temporary" or on-the-road fix to a common NAS problem with its frequent hazard switch failure issue. Just to bide folks time to diagnose by either disassembling & clean/lubricate the internals of the existing switch, source a new switch (tough these days since it's NLA), or change over to the Carling Hazard setup.
My switches all work as they should, quite frankly a Rover probably requires use of its hazards more than any other vehicle .
In my situation the switch disassembly/clean/lubricate worked, but it's a finicky job. Seems like many folks swap over to the Carling ultimately (which is why I came up with the NAS to Carling Hazard Center Dash Face Plate).
signal, switch
MUD UK Hazard Switch Wiring sonoronos Defender Technical Discussions 13 February 27th, 2017 02:18 PM
Hazard switch problem jayz Defender Technical Discussions 12 July 8th, 2012 10:05 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
